Reply
Respected Contributor
Re: Canon 70D lense option
kvbarkley wrote:
No, you want the *new* USM version, it is that much better!*
https://www.usa.canon.com/internet/portal/us/home/products/details/lenses/ef/standard-zoom/ef-s-18-1...
*Now with more NANO!
Other than the ability to use the Power Zoom adapter, I'm not aware of any other advantages for the Nano version over the STM version.
Image quality is identical and to my knowledge build quality is similar.
Esteemed Contributor
Honored Contributor
I think the EF-S 18-135mm f/3.5-5.6 IS STM Lens is an excellent choice.  Just be aware that it is a little too long for the built-in flash.  The lens barrel will cast a shadow.
Your EF-S 18-55mm f/3.5-5.6 IS II lens is short enough so as to not cast a shadow.  But, bringing that lens along brings you back to square one again, carrying more than one lens.  This lens is quite an older design, and has been superceded by an "STM" version.  STM version utilize superior focusing systems, which result in much faster and quieter focusing, and much sharper images.
Your basic dilemma is that you want to be able to shoot two very different scenarios.  One scenario almost requires a wide angle lens, especially if you plan to take any indoor shots, which raises that issue with the built-in flash with the 18-135.  The second scenario that you described would need a medium telephoto.
I think you need to bite the bullet, and just take two lenses.  You will almost certainly want a wide angle for capturing landscapes, and indoor shooting.  You suggested that you wanted a telephoto length, too.
I'm going to suggest that you carry your EF-S 55-250mm and to purchase the EF-S 24mm f/2.8 STM lens.  The 24mm lens is wide enough for indoor and landscape shots.  It uses STM focusing, so it has much sharper images than your 18-55mm lens.  And, it is short enough to not interfere with the built-in flash.
Just my two cents.
Just my two cents.
Waddizzle is right that you need two lenses. But I wouldn't buy a 24mm prime for that trip; it isn't really wide on an APS-C camera. The 18-55 and the 55-250 provide a continuous zoom range from wide to telephoto. But if you don't think the 18-55 is good enough and you want to buy just one lens, get the 17-55mm f/2.8 IS. It's a very good lens and fast enough for indoor use. (But be warned that it too will cast a shadow in the coverage area of the built-in flash.)
Prime lenses have their place, I guess, although the justification for them gets more tenuous as time passes. But their place doesn't (IMO) include travel where space is at a premium.
Bob
Boston, Massachusetts USA
Honored Contributor
Just my two cents.
I had thought, go with what you have, but the kit 18-55mm lens isn't very good.  I had considered the 17-55mm lens, too..  But, it will cast a shadow with the flash, too.  I don't think it would be a good idea to not to be able to use your flash.  I don't think it's a good idea to have only one lens that you can use with the flash, one which is not very good.
I put a priority on being able to use the flash.  Yes, the 17-55mm is a good lens.  But, I think it is bad idea if you are not able to use the flash after traveling that far.  I picked the EF-S 24mm because it is small, which is ideal for traveling.
[ Edited ]
I just tested the EF-S 18-135mm f/3.5-5.6 IS STM Lens on my 7D Mk II.
Without a lenshood the lens does NOT cast a shadow using the built in flash of my 7D Mk II at any focal length.
Occasional Contributor
Hole smoke. So many responces. I am still trying to capture and gather all information. Everyone of you are well informed and amazing for helping me. Kudos to all. Now to search everyone of the options I have received from you guys. I will keep everyone posted.
Basically two versions of the EF-S 18-135 IS lens were recommended by the vast majority of people.
There is a newer STM version and the newest NANO version. The thing is avoid the older non-STM, non-NANO version of the lens. I'm not sure of the price difference between the NANO and STM. Those recommending the NANO are correct it is a little better than the STM version because it has faster focusing. So if they are similarly priced get the NANO one. If there is a substantial price difference get the STM version, its focus is pleanty fast, and its image quality is the same.
Either of those 18-135 lenses are your best 'one lens' solution for traveling.
Honored Contributor
Excellent.  I know for certain that lens casts a shadow with the smaller Rebel bodies.  My son complained about it.
VIP
The question may be what camera should you be taking instead of lens.  If carrying a bag full of lenses or anything approaching that is not wanted, check out the Powershot G1x Mk II. There aren't many camera/lens in the G1 X Mark II's class.
Body of magnesium alloy.   It is easy to hold. Has a built-in grip.  Full manual exposure control.  Macro, too.  The G1 X II has Wi-Fi.
The best part is the new 24-120mm equivalent F2.0-3.9 lens.  Plus the G11x Mk II the 1.5" sensor.  Best of all, it will be very easy to carry.
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
powered by Lithium
