Reply
Occasional Contributor
Canon 100 X 400 4.5 5.6 L IS 11 USM + 1.4 Mark 11 Extender - Focusing Isues
I have just bought this lense to use with my 7d Mark 11 camera and am experiencing problems with focusing at 60/70 yards at 400 with extender. I use AI Servo for birds in flight. F8 - 11. Speed between 500 and 3200. IS0 Auto max 3200. Tracking case 1. It seems to be better at slow rather than fast speeds! Pretty good up to 40 yards using One Shot Mode. I use Centre spot or Extended Cross - can't expand further using using extender. Have not changed Microadjustments. I shoot hand held - birds in flight don't stay still! Have tried all 3 stablizer settings. I have been quite experenced and had good results up to now using my 300mm prime lense. I purchases the 100 X 400 with Extender to obtain better reach as I am missing some shots - very disappointed so far!!Any advice would be most welcome. Thanks in advance.
Richard Sharman
Esteemed Contributor
Re: Canon 100 X 400 4.5 5.6 L IS 11 USM + 1.4 Mark 11 Extender - Focusing Isues
Richard Sharman
The 1.4 extender costs you a full stop of aperture, so at the long end (400 mm) you're trying to focus through an f/8 lens. IIRC, the 7D2 has at most one AF point (the center one) that works at f/8. And if you can use only one AF point, AI Servo isn't going to be very effective.
Bob
Boston, Massachusetts USA
Honored Contributor
I think the problem is your extender.  It sounds like you know what you're doing.  When using the extender, your AF point selection is reduced to just the center point, or the center plus the cross, which do not actually track, but only  serve to "expand" the center point's coverage area.
I say set the extender aside.  I'm not sure if the Mark II extender works with the 100-400 Mark II.  I'm almost certain that you need the Mark III extender for that lens.
Thanks for your reply - my mistake it is the Mark 111 Extender I am using!!
Hi Bob - thanks for your prompt response. Using the Mark 111 extender I can use centre point focus or Extended Cross with Centre point, so I should get some benefit from AI Servo I think.
Thanks
Honored Contributor
Thanks
I assume that you are in continuous shooting mode.  Check your settings for continuous shooting.  Is it shutter priority, or focus priority?  I always use focus priority, even if it slows down FPS.  What's the point of a high frame rate if the shots are out of focus?
Also, the AF speed of the combo is slower when using the extender.  I have had better success with Case 2, where the sensitivity and tracking are at a minimum, when using the extender.
I usually use IS mode 2 on the lens for tracking sports like baseball and football.  It also seems to work for when the occasional bird might fly overhead, too.  Of course, your focus mode switch would be set to 3m to inifinity.
Again, try the lens without the extender.
Thanks Waddizzle for your detailed suggestions. Yes I do use continuous mode and I also use Priority set to Focus on shot 1 and on shot 2. This has worked well using my 300mm.  I have only used Case 1 so I will definitely try Case 2 as suggested. I will try this with IS Mode 2. Yes I am set 3m to Infinity.
thanks
Richard
Honored Contributor
[ Edited ]
RobertTheFat wrote:
Rsharman wrote:
Richard Sharman
I agree with Bob, to a point.  AI Servo will still be effective, but it will just be much harder to use.
I have found that I get better success by prefocusing on a zone ... which is next to impossible to do with BIF...but  I am mostly shooting sports, where you can predict where the next shot is most likely to be.  And, I do not just prefocus, I use BBF to keep the shutter from refocusing when I press the shutter.
You may have a bad copy of the lens, but it is unlikely that is the case.  The one time I had a bad "L" lens it was because the box had been opened, and the weather sealing ring on the lens mount had been removed.  The lens rattled when it was mounted to the camera because the rubber ring was missing.  I do not buy big ticket items from Big Blue Box stores, anymore.
[EDIT]  When using the extender, I also use quiet continuous shooting mode, which slows down the frame rate, and gives the camera more time to analyze focus.
I think the lense is good as I have some very nice, in focus birds in flight at about 30/40 yards and also one shot staionary shots. It's when I am shooting at 400 + extender. I will try continuous in silent mode and also try with Case 2 tracking with IS 2
I will keep you both posted. I need some sun to give it a fair chance at 60 /70 yards - weather is appauling here at the moment.
Thanks to You both for your advise.
Regards
richard
VIP
I read this thread with some interest.  For one thing I am not a fan of using tel-cons at all.  Much preferring one of the 150-600mil super zooms over the 100-400mm.
This is puzzling to me.
" Pretty good up to 40 yards using One Shot Mode" "I have some very nice, in focus birds in flight at about 30/40 yards""...give it a fair chance at 60 /70 yards"
What does the distance have to do with it?  It should make it easier to get an acceptably sharp photo. The DOF will become larger.  What do you intend on doing with your photos?  Are you doing excessive cropping for instance?  If so the loss of resolution might be what you are noticing as OOF shots.
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
powered by Lithium
