Reply
New Contributor
Re: Autofocus not working. (18-55mm lens)
Hi Crystal,
  I have been having the same problem with my 18-55mm lens.  I am not sure if I am pulling the focus ring how I should.  Can you offer any further advice?
  Thank you
New Contributor
Thank you SO MUCH - worked like a charm - and to think I was about to give up and toss it!
New Contributor
Thank you!!! Followed the steps above and my lens is back to normal!!! ((Virtual hug))
New Contributor
I can't believe your tip actually worked!!! I am estatic!  Thank you so much.
New Contributor
[ Edited ]
Ohh, thank you all so much, this last little trick worked for me. This lens is only 3 years old and has never been abused. But I tried the GENTLE tug on the focus ring and heard the tiniest little click, re-attached it to the camera and VIOLA IT IS NOW WORKING!!!
New Contributor
Thanks for your tips on restoring the autofocus on the 18-50mm kit lens. it now works fine.
It has saved me buying a new lens.
Thanks again from the UK!
New Contributor
Has anyone experienced this issue but only focussing one way? My lens will focus on a subject further away but refuses to focus back to nearer subjects. Its such a pain having to set to manual in order to reset the focus to near everytime!
New Contributor
Crystal! It worked! Here I've allways prided myself as being a hi tech cowboy. Of course i tried everything before going to the net. & of all things...all i had to do is pop a top! haha! TKU ! TKU ! TKU! I owe u a squeeze...i mean a hug..lol
New Contributor
You are genius!! I registered as a user here just to thank you for your advice. I had a similar issue with AF not working. It worked with my zoom lens, but not my 55mm lense. I looked up the issue online and finally came across your suggestion of the chiropractic tecnique. It did snap when I turned it and now it works perfectly! Thank you very much for your help!!! You rock!
New Contributor
Crystal:
Thank you for your brilliant suggestion, my autofocus is now working again!  I had tried the suggestions from Julius but no success, so I had nothing to lose by trying the gentle pulling on the focus ring and it worked - totally made my day!
I also took note of the comments saying that the main reason the problem occurs in the first place is the user is focussing manually when the AF is engaged - I'm sure I've been guilty of this in the past, without even thinking about it, so I will be more careful to avoid doing that in the future!
I also appreciate the comment stating that it's a good idea to put the lens in the MF mode when it's not in use, I will add that suggestion to my repertoire...
powered by Lithium
