Reply
New Contributor
All lenses should have the exif info come up on photos, not just canon
Hello , I have a suggestion. I just noticed that my  Tamron150-600 serial number does not show
up on the photo information. Usually all canon lens serial numbers will show up in the EXIF data.  But listen Canon,
your customers typically spend a lot of money on our(Canon) cameras and lens.  A lot of money.  This Tamron
lens is the only one that is not Canon that I own. That is because I cannot shell out $6000.00. for your lens. It would
be nice if you could post the other guys EXIF info, just because you ARE the better brand. With our equipment getting stolen
as mine has been any little stop or security measure that can nail the thieves helps. Lets unite and be against the thieves and not the competition and the customers. Just a suggestion.
Cheers
Esteemed Contributor
Re: All lenses should have the exif info come up on photos, not just canon
We are not Canon. We are users like you. We don't know if any suggestions here reach the proper ears.
VIP
"Just a suggestion."
Not a reasonable one.  Why didn't you write down the lens' serial number when you bought it. Did you register it with Tamron?  They would have wanted the serial number.   Would that not have been a better idea than to expect a one company to keep track of a competitors products?  I doubt you are going to find any company, not just Canon, that is willing to do that.
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
Valued Contributor
It may not be Canon's fault that the serial number does not show up in the EXIF information.
Tamron has to reverse engineer their lenses to work with Canon cameras and it's possible they were unwilling or unable to include the serial number in the EXIF info.
Mike Sowsun
S110, SL1, 80D, 5D Mk III
Cheers
Where does the serial number of a Canon lens show up in the Exif data? I've never seen it in any version of DPP, even with my most recently purchased Canon lenses.
Bob
Boston, Massachusetts USA
I only see the body serial number when I search my EXIF data (inspecting images taken using Canon lenses).  Neither Lightroom nor DPP 4 show a serial number for any lens.
EXIF does support having a lens serial number field, but I don't think Canon uses it.
Actually, I'm doing some digging into the specs.  The ability for EXIF to support lens serial number may actually be a new-ish thing (possibly requiring a more recent EXIF spec.)   I'm not certain, but it looks like older EXIF specs may not have even supported lens serial numbers.  In any case, I certainly don't see them in the EXIF data for Canon cameras (it doesn't seem to be just 3rd party lenses that are not included.)
I notice some docs mentioning tags that were added in EXIF 2.21 and I don't see lens serial number.  The latest spec is 2.31... and the guide I'm looking at underlines what they've either added or updated and it's showing the lens serial number data as being one of those "new" things in the latest spec (or it was updated).
Not an exhaustive search, but at first blush, it looks like the ability to record a lens serial number based on EXIF tags might be new.
Tim Campbell
5D III, 5D IV, 60Da
Valued Contributor
[ Edited ]
I have seen serial numbers show up in EXIF data, but in this case with Irfanview and Opanda, they both show the same incorrect serial number on my 55-250 STM. The camera serial number is correct as shown in the EXIF data below my name.
Mike Sowsun
Given what Tim's research unearthed, I'd be surprised if many existing lenses even knew how to provide their serial numbers to the camera body.
In that vein, my cameras are able to keep track of AFMA settings for only one lens of each type. That restriction wouldn't be necessary if the cameras could read the lenses' serial numbers.
Bob
@MikeSowsunwrote:
I have seen serial numbers show up in EXIF data, but in this case with Irfanview and Opanda, they both show the same incorrect serial number on my 55-250 STM. The camera serial number is correct as shown in the Irfanview EXIF data below my name.
Are you sure that lens serial number is incorrect? It could be being displayed as a hexadecimal number.
Bob
Valued Contributor
[ Edited ]
The lens serial number in this case is incorrect. I have seen my 24-105 show correctly with my 5D3. I am not sure if it just this photo is wrong with my 55-250, or others too. I will check and report back. .
Mike Sowsun
powered by Lithium
