11-30-2016 10:14 AM
I guess that I've been thinking too much again.
I've run up against one of those, "Now how is that supposed to work," issues. Except for the high end models, most of Canon's DSLRs cannot focus at f/8. The cameras seem to top out at f/5.6.
But, some lenses, like a Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary, can stop down to f/6.3 at the long end of the zoom range. So, how is the AF systemsupposed to work properly when the lens stops down that far?
I've used the "big Siggy" on camera bodies that focus to f/5.6 and others that can focus at f/8. The f/8 camera bodies seem to focus more accurately at maximum zoom than the f/5.6 bodies. Granted, the focus systems are not the same, which probably explains most of the differences.
But, how are the f/5.6 bodies supposed to auto focus when the lens itself stops down to f/6.3? It seems to work, but why?
11-30-2016 11:47 AM
http://www.the-digital-picture.com/Photography-Tips/canon-eos-dslr-autofocus-explained.aspx
See "Lines, crosses and double crosses" section.
11-30-2016 10:17 AM
I have heard that the Sigma/Tamrons simply tell the system that they are at F5.6 during autofocus.
11-30-2016 10:23 AM
@kvbarkley wrote:I have heard that the Sigma/Tamrons simply tell the system that they are at F5.6 during autofocus.
Oh, so they cheat. Well, that's a sensible explanation.
Do you think that might explain why images shot with f/5.6 bodies seem softer than those with f/8 bodies?
11-30-2016 10:59 AM
I would think it the other way 'round. The problem with focussing with small apertures is that there is a large "dead zone" because of the depth of field, which I guess gives the control algorithm fits.
11-30-2016 11:16 AM
@kvbarkley wrote:I would think it the other way 'round. The problem with focussing with small apertures is that there is a large "dead zone" because of the depth of field, which I guess gives the control algorithm fits.
Yeah, that makes sense, too. That might explain a lot of things. If the camera thinks the aperture is f/5.6 when it atually is not, I can see how that might throw things off just a little. The hyperfocal distances would differ significantly.
11-30-2016 11:47 AM
11-30-2016 01:10 PM
@jrhoffman75 wrote:http://www.the-digital-picture.com/Photography-Tips/canon-eos-dslr-autofocus-explained.aspx
Most of the stuff in the entire article I am already familiar with, which is what prompted the question in the first place. The explanations of ALL of the different AF sensors went into more detail than before. I think this excerpt....
"Note that these thresholds are not absolute - a lens with a narrower aperture than the threshold might still work, but at reduced effectiveness, accuracy, and speed. Thus, Canon limits the functionality to the rated aperture for a given AF sensor. However, some third party lenses (e.g. Tamron and Sigma zooms with a max aperture of f/6.3 at the long end) effectively trick the AF system into thinking there's an f/5.6 lens attached."
... seems to confim my observations that f/5.6 AF point bodies are giving softer images than f/8 AF point bodies. It may also explain why the lenses occasionaly seem to hunt more at the long end, too.
I have previously heard about how some 3rd party lenses with narrow apertures fool the camera body into thinking that it using a wider aperture lens. The only problem with that suggestion is that the aperture is still somehow reported correctly in EXIF data.
12-01-2016 09:23 AM
It has to do with accuracy and cross-type focusing. In order to make sure you get accurate and reasonably quick AF, Canon limits it to f5.6. Except on the higher end cameras where the extra grunt can be added.
Sigma and Tamron lenses report f5 to the camera so they will work. The actual aperture is recorded when you shoot.
If you want to test this you can tape three of the pins on a tele converter and try it. This will fool the camera and it will think you have what ever lens you have attached. So if it is a f5.6 lens the camera will still think it is a f5.6 lens. The lens will AF albeit slowly and maybe not to accurately even though the converter changed the f5.6 to f8.
12-01-2016 11:13 AM
@ebiggs1 wrote:It has to do with accuracy and cross-type focusing. In order to make sure you get accurate and reasonably quick AF, Canon limits it to f5.6. Except on the higher end cameras where the extra grunt can be added.
Thanks, I've been curious as to why I seemingly get softer images with an f/5.6 body, compared to an f/8 body, at the long end of the 150-600. I've seen it enough to know it's not my imagination.
11-30-2016 04:35 PM
I think it's because Canon made an arbitrary decision not to allow focus beyond f/5.6 for their lower end cameras to prevent people complaining about the AF systems. There is no physical limitation say at f/8, just that it doesn't always focus well. For this reason...the Sigmas and Tamrons can report to the camera AF something else like f/5.6 (and report to exif the correct value of f/6.3) and the AF system is fat dumb and happy autofocusing away...
This is the same reason you can tape off the 3 pins on the teleconverter and fool the cameras into letting you focusing at f/8. I used to do this a lot with my old 50D.
