01-27-2017 05:45 PM
I have a f/2.8 17-35 that the auto focus switch fell off of. The autofocus is still working but I can't seem to switch it to manual if I'd like to and I do need to for work sometimes . Photos below
01-27-2017 06:22 PM - edited 01-27-2017 06:24 PM
@Jawkurt wrote:I have a f/2.8 17-35 that the auto focus switch fell off of. The autofocus is still working but I can't seem to switch it to manual if I'd like to and I do need to for work sometimes . Photos below
Do NOT try to Super Glue it back on! Super Glue can off gas and fog the lens elements.
But, if you don't want to send it in for service you might try hot gluing it back on where you see the glue remains on the short edges of the switch plate..
01-28-2017 11:13 AM
You have this lens, Canon EF-S 17-55mm f/2.8 IS USM Lens ? Is it still under warranty? Whether or not send it to Canon for service. Asking questions on how to fix it, indicates it is best left to Canon. Whether it is your dime or there's is the question. They just might fix if for free anyway!
01-28-2017 12:53 PM
@ebiggs1 wrote:You have this lens, Canon EF-S 17-55mm f/2.8 IS USM Lens ? Is it still under warranty? Whether or not send it to Canon for service. Asking questions on how to fix it, indicates it is best left to Canon. Whether it is your dime or there's is the question. They just might fix if for free anyway!
EF-S has a white dot. Not a red one. 17-35/2,8 was made between 1995-2001.
01-28-2017 01:12 PM
Great eye, Peter!
The EF 17-35 F/2.8 L USM came out on April 1, 1996, and we unfortunately stopped servicing it at the end of 2008.
01-28-2017 01:17 PM
@Stephen wrote:Great eye, Peter!
So, DIY with glue is the solution? Seems like it was glued from the start.
01-28-2017 01:41 PM
Evidently they learned their lesson. The corresponding switch on the EF-S 17-55mm f/2.8 appears to be held down by a screw.
01-28-2017 02:22 PM
Hey yeah, Its an old lens and I knew Canon doesn't service it anymore. You don't get any points for it when signing up for pro services... it kinda doesn't count anymore... but I think its a much cheaper alternative to the 16-35 and I'm happy with it. I know I could glue the button on... but I'm concerned about how to get it attached again in a way where the switch will work. I've tried pushing that tab around a bit on the inside but can't seem to get it to click to autofocus being off.
01-28-2017 02:47 PM
EF 17-35 F/2.8 L USM ?
I don't believe I am familiar with that lens at all. Or at least I don't remember it.
