Reply
New Contributor
Windows 10 Edge Browser and Secure Print Not Working
Environment:
imageRunner ADVANCE C5240i PCL6
Driver version: 21.65.0.0 (x64)
OS Version: Windows 10 Professional x64
Secure Print is the default Output Method
The printer is attached to a print server and is shared.
I can print from my Windows 10 PC via various applications including Internet Explorer and Chrome however when printing from the Edge browser, I don't get the Secure Print pop up to enter a PIN. Instead this jams up the print queue and we've had to clear the queue manually and forcefully.
I've only managed to find this discussion from Microsoft with other users reporting the issue however no resolution:
http://answers.microsoft.com/en-us/windows/forum/apps_windows_10-msedge/how-enable-pin-protect-in-mi...
I've updated with the latest driver however this doesn't resolve the issue with Edge. Anyone know of any solution and/or workaround to this?
Moderator
Re: Windows 10 Edge Browser and Secure Print Not Working
Hi, wsamaroo! Thanks for posting!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area!
We hope this helps!
Highlighted
New Contributor
Thought I would share what worked for me for anyone else who comes across this.
I was having the same issue with canon secure print in edge and photos in windows 10 using a print server. I was able to resolve the issue using the following steps.
  • Log onto the print server and open print management
  • under the "Drivers" section on the left hand side of print management, right click on the canon driver, go to isolation and select "none"
  • under the "Printers" section on the left hand side of print management, right click on the canon printer and select properties
  • in properties go to sharing
  • under sharing, deselect "Render print jobs on client computers"
  • Click "Apply", "OK"
  • right click on the canon printer again and select properties
  • under sharing, reselect "Render print jobs on client computers"
New Contributor
I had the same issue with a ricoh printer and your solution worked perfectly for me too! Thanks!
New Contributor
Thanks its resolved in my case too
powered by Lithium
