Reply
New Contributor
Accepted Solution
The printer does not work
Hello forum! I am happy to find a forum where I can figure out my printer!
I would like to know why the printer used for a long time, the original or normal use, suddenly the printer light flashes, the printer does not work?
what is the reason? How should I fix it?
Hope someone can help me, thank you!
Highlighted
Occasional Contributor
Re: The printer does not work
Ink jet printer has a waste ink pad, its role is to absorb the print head cleaning when the exhaust ink. The amount of ink consumed by each printer in different ways is different, and is controlled by the main board. The counter accumulates the amount of ink (i.e. waste ink) that is consumed every time the head is washed. When the cumulative amount of waste ink reaches the upper limit, the printer will stop working and prevent the ink from being filled with ink. The ink will drip into the printer and damage the printer.:smileytongue:
If your printing is particularly large, note that the printer may use the 20 cartridge, and the printer might have this problem. If such a problem occurs, it is better to send the printer to the service station, replace a new waste ink pad and reset the waste ink counter.Smiley Tongue
New Contributor
Re: The printer says "printer not responding" a cannon mx535
I have been through the detection of fault to no avail.
New Contributor
  There may be a foreign body inside your machine
New Contributor
What should i do?
New Contributor
Re: Printer prints small and in one corner of the paper
Hi! I have a pixma mg2922 and windows 10. It has been working well, but just recently it just prints very small and in the upper left corner of the sheet. I probably did something but have no idea what.
Hi Bob87,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
powered by Lithium
