Reply
New Contributor
LIDE 120 w IJ Scan Utility - why no Stitch button visible, no Make searchable pdf option etc?
[ Edited ]
Hi
Just bought the Lide 120 which I'm using with my win10 (Anniversary) laptop. INstalled and worked okej. But, according to specifications and manual, there should be a Stitch button option in the menu. But there is no one on mine. Only  Automatic, Photo, Document, Custom, Settings and ScanGear scan buttons are available.
Why is Stitch buttton missing, since the LIDE 120 should have it?
My other question concerns pdf options. In my old CanoScan 30 with my old xp laptop there was an optio to make searchable pdf. In the LIDE 120 with IJ Scan Utility there is only the option  Create PDF that supports password.
Should it not be any option for making searchable pdf's?
And what about manual Text enhanced options? Is it ON automatically all time or should there be check box for it?
Regards
Martin
Re: LIDE 120 w IJ Scan Utility - why no Stitch button visible, no Make searchable pdf option etc?
Hi marp68,
Stitch should appear on the IJ Scan Utilty.  Please uninstall the CanoScan LiDE 120 and the reinstall using the latest driver.
To download and install the latest driver, please follow these steps:
 1.  Visit Canon's website at: http://usa.canon.com/support
 2.  Type CanoScan LiDE 120 in the "Enter a Model" box and click GO.
 3.  In the Drivers & Downloads section, please click the Select button next to the CanoScan LiDE 120 Scanner Driver.
 4.  Click the Download button.
 5.  If a Save dialog box appears, click Save.
 6.  Once the download is complete, open the Downloads folder.
 7.  Double click [sc68-win-lide120-1_02-ea33_3.exe], follow the prompts and the installation will complete.
Once reinstalled, the Stitch button should appear on the IJ Scan Utility.
In regards to creating a searchabel PDF, please enable "Create a PDF file that supports keyword search" in the IJ Scan
Utiltiy.  To do this, please follow the steps in the On Line Manual:
http://Canon.us/ksur
There isn't a "text enchanced" option, but there is a "sharpen outline" option.  In the Document Setting page, please click on the + next to Image Processing Settings to access this.
New Contributor
[ Edited ]
Hi
Thanks for your quick respons.
Unfortunately it didn't work. I uninstalled, installed the downloaded latest and rebooted. No Stitch button showed up.  Please see image. It's in Swedish, but I think you understand by the icons. Btw, I already had the same (latest) driver version.
Regarding the pdf searchable option, there is none. Only the password option, which is anabled in the image.
And unfortunately no Sharpen Outline option neither.
I use the Quick Menu version 2.7.0 (Swedish).
Strange indeed. I'm lost :-(
Hi marp68,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
Highlighted
New Contributor
Hi
Thanks. I contacted Canon in Sweden. They had never heard about this issue and would have to look further into the matter. investigate it.
Regards
Martin
powered by Lithium
