Reply
New Contributor
Default File Location for My Image Garden Saved Disc Label Files
I have been burned once and trying to avoid it happening a second time....
My computer hard drive became corrupt and I had it replaced.  I faithfully backed up my data files - but not able to do so for the disc label files I created in Canon's My Image Garden application.   As best I can tell, the application does not have a preference option to set or change the file location for my custom labels.  Now that I have reinstalled the printer software (including My Image Garden software) I would like to include these files in my backups.   Please advise.
Re: Default File Location for My Image Garden Saved Disc Label Files
Hello.
The only options that appear to be available as far as files are concerned are the locations for temporary files and for where scanned images can be saved to.  You may not be able to export other data from the program.
For additional assistance, contact our support group using the Contact Us link below.
New Contributor
Thanks for the quick reply, Michael.    Maybe there is a legitimate reason - but from a user perspective this is pitiful software design...and demonstrates that Canon doesn't meet the standard that I was used to with the Epson EasyCD application.
New Contributor
For what it's worth I agree with you that we should be able to determine where those files are stored. I also was an Epson user, but my old Epson finally kicked the bucket and I bought a Canon. The Epson software was definitely superior, although this Canon is way faster than the Epson.
Anyway... I'm surprised however that the Canon expert wasn't much more helpful. The files you are looking for (at least in Windows 7, if you're using another operating system they'll be somewhere similar) are in:
C:\Documents and Settings\Your Name Here\AppData\Roaming\Canon\My Image Garden\AddOn\DiscLabelPrint\work
Here you'll find a bunch of randomly numbered directories that store the info you want (along with what seems to me to be a bunch of unnecessary info). So if you back up the work directory you should have what you need.
Hope this helps. --ds
New Contributor
Thanks for the info, DS.  I am using Windows 10 where I believe the corresponding location would be:
          C:\Users\{user name}\AppData\Roaming...
I'm not able to find any folders under "Roaming" other than "Microsoft".
Highlighted
New Contributor
Just installed "My Image Garden" and was also wondering where the file for the disc label was stored so I could back it up !  This issue does seem to be a weakness in the softwre. The old .cld system was easier to use. Can't understand why it is not still avalibale ( or something similar ).  Come on Canon, pull your finger out ! [using Windows 10].
powered by Lithium
