Reply
New Contributor
Re: CanoScan LiDE 220 error > Cannot communicate with scanner Error 2, 156,182
I have had the same problems. I replayced the power USB cable with faran and it worked again.
New Contributor
Could you tell me what is USB cable with faran??
Moderator
Hello Somy!
The CanoScan LiDE 220 uses an A to mini B USB cable. If you have additional questions please contact our Technical Support Team at 1-800-OK-CANON (1-800-652-2666). They are open Monday through Friday from 10 am to 10 pm ET, excluding holidays.
We hope this information was helpful!
New Contributor
[ Edited ]
Sorry for wrong text.
USB 2.0 Hi-Speed A/B Cable with Ferrite Chokes
This cable has solved my problem and my scan is now Ok again.
[Mod Note: Removed 3rd party link per Forum Community Guidelines.]
Buy it everywhere.
Best regards,
Dan
New Contributor
Thank you Dan1959,
But the original Canon cable is already with Ferrite Choke??
New Contributor
I changed the cord to a different USB port on my PC and it worked perfectly fine. ?? it just maybe needs a higher power USB port....
regards,
Deb
New Contributor
I had this same issue, contacted Canon upport and they just told me to uninstall and reinstall the drivers.
The solution that I found to work for me was to use the windows store scanner app. This works every time.
Occasional Contributor
Re. "The solution that I found to work for me was to use the windows store scanner app. This works every time" - which scanner app have you found works for you.  There are several.
Thanks.
@Somywrote:
Hello,
I have the same problem with Windows 10 and num error 2,156,55!!
It's my second scan Lide220, because I thought it was my scanner didn't work and brought to the shop...
Should I bring back again??
Somy,
The drivers will have to be uninstalled and reinstalled.  The software is attempting to access your old scanner.
Disconnect the USB cable from the scanner.  Then uninstall the IJ Scan Utility and CanoScan LIDE 220.  Once this has been done, visit www.usa.canon.com to download and reinstall the latest drivers.
If you continue to have difficulties, find more help at Contact Us.
powered by Lithium
