10-15-2017 02:54 PM
I have two new P23-DH V calculators and it is frustrating that the calculator turns off after a few minutes. Is this a setting that can be changed or just something to live with? I purchased two at the same time and both do this so I know it isn't a problem with the calculator. I don't see anything in the manual about it - and I don't recall seeing anything on the specs about it. Has anyone else run across this or am I the lucky one?
11-03-2017 03:16 PM
Hello mcalister7353,
When the P23-DH V calculator's power is turned "ON" and the calculator is not being used for approximately 7 minutes, the calculator will switch off automatically. See "Automatic Power-off" under "Specifications" in the Instructions. Click HERE to view a PDF version of the Instructions for your P23-DH V. When you are not actively using your P23-DH V calculator, pressing the CE/C button every 5 to 6 minutes will prevent the unit from turning off.
03-23-2021 12:42 PM - edited 03-23-2021 12:43 PM
This is the worst feature ever for a calculator that is plugged into a power source. I can understand this feature when calculator is being used in battery mode.
I will be returning it, as I can't be turning it on and off all day.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
