06-20-2017 11:04 PM
06-21-2017 04:41 AM
@Miagd69 wrote:
Looking for suggestions. Just got a new camera and when I turn it on the flash pops up and the camera takes a couple pictures. The screen on the top of the camera says busy while it does this. This occurs every time I turn it on. Any suggestions are appreciated. Using a 16-300 tamron lense.
Thank you!
If the camera is new, then it should be under warranty. You can contact US support at 1-800-OK-CANON. The Canon web site has a link for international users.
Do you have a Canon lens that you can try?
Does the camera return to "normal" after it takes a couple of shots?
What happens if you power up the camera with a different lens [Canon], or no lens?
Have you tried going into the menus and resetting the camera back to "factory defaults"?
06-21-2017 11:56 AM
While this is definitely not normal behavior... try removing everything NOT made by Canon from the camera ... and then turn it on (you can turn on a camera with no lens at all).
This means you should remove the Tamron lens (if you don't have a Canon lens then leave the lens off completely but you might want to put on the front dust cap on the body to prevent dust from getting in).
If you've installed a 3rd party battery grip, take that off.
Now try turning on the camera... does it still take exposures when powering up?
06-21-2017 09:15 PM
06-23-2017 12:04 PM
I think having a battery grip is a minor detail you left out of your OP.
06-23-2017 01:20 PM
