02-01-2016 06:17 PM
Does anyone know if you can adjust these setting to help lower "Red" intensity?
02-09-2016 11:39 AM
02-09-2016 05:21 PM
02-09-2016 07:36 PM
What are you using for post processing the images (and are you shooting RAW)?
Good image adjustment software (e.g. Lightroom) will let you adjust saturation or luminance by color (you can desaturate or decrease the brightness of just one particular color without effecting the others.)
Also, many programs that allow you to adjust "levels" are typically showing you the "luminance" channel (the luminance channel is the entire visible spectrum of light) but many of the better editors will let you pick just one color channel and adjust levels on that channel alone.
I wouldn't fuss over the picture styles.
02-13-2016 10:34 AM
@TCampbell wrote:What are you using for post processing the images (and are you shooting RAW)?
Desaturating a single color works if that color is too prominent over the whole image, but in this case it could drain red out of places that need it. A better approach might be to suppress the highlights (since that's evidently what the red lights are in this situation). DPP lets you do that, so the Adobe products probably do as well.
02-13-2016 01:00 PM
You can localize any adjustment in LR by "brushing over" the adjustment area. Any global adjustment (exposure, contrast, highlights & shadows, white balance, saturation, etc. etc.) can usually also be applied to a brushed on area.
02-14-2016 07:53 PM
Lightroom CC and I shoot in RAW.
02-14-2016 09:30 PM
