06-12-2015 10:59 PM
Can anyone tell me what is going on here? This isn't the only picture. Everything was fine at the beginning of my hike. The camera was not dropped. I did not change lens. This streak showed up very slight at first, not even noticeable until I went back through the pictures. I have changed lens and it still appears so I assume it's the camera. Any suggestions would be appreciated.
Camera Model Canon EOS 70D
Shooting Mode Program AE
Lens EF28-135mm f/3.5-5.6 IS USM
Focal Length 109.0 mm
Tv( Shutter Speed ) 1/500
Av( Aperture Value ) 10.0
06-13-2015 06:03 AM - edited 06-13-2015 06:10 AM
Broken shutter. Common on 70D I would say. You need to send it in for replacing the shutter.
Your shutter should looks like this http://commonsensephotography.com/img/web/shutter-shutter.jpg
In your case, one of the blades are stuck.
06-13-2015 09:48 AM
Thanks Peter! I figured I had to send it in. I appreciate your time and advice.
Kristina
