11-22-2017 04:46 PM
Just curious, about this remote controller. I have one fo the "older" ones which is just basically a remote shutter release. I was looking to buy a second one as I find it is always nice to have a backup. Now I find that Canon has upgraded this to a full blown remote that funtions as an intervalometer, a remote shutter control, a self timer and an interval timer. I did not know when this "upgrade" occurred, so I am just wondering if anyone knows when Canon did this. Not that I object, but it makes for a completely new piece of gear in my bag.
WesternGuy
11-23-2017 04:24 PM - edited 11-23-2017 04:26 PM
@WesternGuy wrote:Thanks diverhank. I am still learning about the capabilities of my 5D4, so I will have to check that functionality out. I wasn't aware that this was a capability of the touch screen when using the LiveView mode. I need to read a bit more of the manual .
WG
If it is only one second, that may not be near long enough for many budget priced, professional grade tripods and heads. In fact, I am going to declare that it is NOT long enough.
You would need to use a pretty robust tripod, one that does not use a center column, and a fairly robust head to match. Many budget tripods with center columns can resonate and vibrate like a tuning fork for a few seconds with their center columns raised..
If you have the time to use the 10 second timer, then use that. Otherwise, I would still use a wired remote with $200 tripod kit.
11-23-2017 04:29 PM
@Waddizzle wrote:If it is only one second, that may not be near long enough for many budget priced, professional grade tripods and heads. In fact, I am going to declare that it is NOT long enough.
Good point - since I don't have the camera...I don't know whether you can program the time delay. Also keep in mind, it's a very light tap on the screen unlike a shutter button push so it's not as bad.
11-23-2017 04:31 PM
Waddizzle, thanks for the insight. How about a Gitzo 3532LS and a Real Right Stuff BH55 Ball head? Regardless. I will still use the wired remote.
WesternGuy
11-23-2017 05:48 PM
@WesternGuy wrote:Waddizzle, thanks for the insight. How about a Gitzo 3532LS and a Real Right Stuff BH55 Ball head? Regardless. I will still use the wired remote.
WesternGuy
That will work! That'll work well, as a matter of fact. I like the idea using the wired remote, too. The less touching, the better. Get an iPad and shoot tethered.
