Reply
Respected Contributor
Re: Refurbished 80d...blurry out of focus photos.. HELP!
KevinG1 wrote:
So your saying if i have 20 points focused on the car, and a couple on the pavement, that it will focus more on the pavement instead of the car because its closer? Even though the car was lit with squares?
Yes
Frequent Contributor
I researched as much as possible on the 45pt af and never saw anything saying that. But i guess it makes sense. So basically makes A+ useless shooting car photography. Guess ill just stick to single or 9 point af
[ Edited ]
It was covered in Rudy Winston's presentation (the 3 videos I linked to), in the first video around 18 minutes in.
Yes, A+ lets the camera decide everything and it doesn't know what you are thinking it has to make its best guess.
edit: note the nearest AF point applies to One Shot and not to AIServo. The camera behaves differently in AIServo, rewatch Rudy Winston's presentation to understand how it differs.
I did watch all of the video. Guess i didnt full understand the 45 point section when he was talking about the 5d. Just made it sound more selectable.
Well guess this is my issue. Thank everyone for helping me out!
Esteemed Contributor
A+ Mode as well as Auto Point Selection in any other mode is not the best choice for any situation where the full AF “window” can see anything that is closer to you than the main subject you want to photograph.
If you let the camera think it will assume you want to photograph the object closest to you. Try photographing a bird in a tree. If you don’t select single point AF invariably it will choose one of the branches closer to you.
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472
Gotcha. Ill just need to shoot more and see what methods work best for me.
Also i did a micro af adjustment and found my canon 50mm 1.4 was off a bit. Definitely wasn't helping me
Honored Contributor
I suggest that you reset your AFMA back to zero, until you gain more experience with the camera.  Learn how to half press the shutter when using One Shot mode, so that you can evaluate the AF points.
When you have all AF points active, like [A} mode, you may see multiple AF points light up.  Be aware of the fact that the camera is indicating which AF points are capable of achieving a focus lock, but only one AF point will actually be used to focus the shot.  The automatically selected AF point will typically rest on the closest object under an active AF point.
It is highly recommended that you configure the camera to always use the center AF point, which is the most sensitive and accurate AF point.  And, always use One Shot focusing mode, until you gain more experience using the camera to focus on the subject that you want.
One final note.  The AF points are actually slightly larger than the red boxes you see in the viewfinder.  Placing an AF point on something may not always focus where you want it to.  The camera will focus on the highest contrast area that it can find within the AF point coverage area.  So aim your camera at vertical and horizontal contrasting lines.
Thank you for the pointers
Occasional Contributor
I have a brand new 80D and I have the same viewfinder vs. live view focus problem.  I think it's the camera.  These images were shot using a tripod and timed (2 s) shutter release.  My hands did not touch the camera when the pictures were taken.
One shot, single, center point autofocus, 24mm, iso 400, f 2.8. It's a little hard to see, but the top image was autofocused through the viewfinder. The bottom image using live view.  My old Rebel T1i takes better pics. Guess I have to send the camera in for warrenty repair.  Very disappointing, brand new $1100 camera.Compare.jpg
Its not the camera. Read the post. It has to do with using the 45pt autofocus
powered by Lithium
