10-26-2017 10:05 PM
10-30-2017 06:36 PM
@KevinG1 wrote:
Gotcha. Ill just need to shoot more and see what methods work best for me.
Also i did a micro af adjustment and found my canon 50mm 1.4 was off a bit. Definitely wasn't helping me
I suggest that you reset your AFMA back to zero, until you gain more experience with the camera. Learn how to half press the shutter when using One Shot mode, so that you can evaluate the AF points.
When you have all AF points active, like [A} mode, you may see multiple AF points light up. Be aware of the fact that the camera is indicating which AF points are capable of achieving a focus lock, but only one AF point will actually be used to focus the shot. The automatically selected AF point will typically rest on the closest object under an active AF point.
It is highly recommended that you configure the camera to always use the center AF point, which is the most sensitive and accurate AF point. And, always use One Shot focusing mode, until you gain more experience using the camera to focus on the subject that you want.
One final note. The AF points are actually slightly larger than the red boxes you see in the viewfinder. Placing an AF point on something may not always focus where you want it to. The camera will focus on the highest contrast area that it can find within the AF point coverage area. So aim your camera at vertical and horizontal contrasting lines.
10-27-2017 12:05 PM
I get the same results using different lenses. I tried micro focus adjustments with my canon 50mm 1.4 and it just seemed to get worse
10-27-2017 12:16 PM
@KevinG1 wrote:I get the same results using different lenses. I tried micro focus adjustments with my canon 50mm 1.4 and it just seemed to get worse
Please take the time to review the links I provided, even if they don't solve your problem, they will make you a better photographer.
10-27-2017 01:57 PM
1/60 is a slow shutter for handholding a 50mm lens on a crop sensor. The general rule of thumb for full frame sensors would be a shutter speed at least as fast as the reciprocal of the focal length. On a crop sensor you must multiply the minimum speed x 1.6. So a 50mm lens on a crop needs at least 1/80 second or faster. A 100 mm lens on a crop needs at least 1/160 second or faster. At 200mm you'd need 1/320 or faster shutter.
Here it is front focusing though. It could be the AF system making a wrong guess. See if the AF system can focus right by simplifying things. Use your f/2.8 again but go into the AF point selection and select ONLY the center af point to be active so you can tell the camera what to focus on. Either use a tripod or use a plenty fast shutter speed (1/100 minimum or if possible faster like 1/200 or 1/400 if there's enough light). Place that selected af point on the subject and take the picture. See if it focused where you told it to. If it just can't do that then you probably have a problem with the camera. If it does focus you know the problem is not the camera.
10-27-2017 02:02 PM
One other thing is do the test on a non reflective surface. If the car has a nice mirror finish then the camera may try to focus on a reflection instead of the car. Use something non shiny and something with clear contrast and edges (not a plain smooth wall) as the subject.
10-27-2017 10:48 AM
@KevinG1 wrote:
Unfortunately you saved the above image without any EXIF information, so it it hard to tell what is actually going on.
The photo does seem to be front focused. That can be caused by a couple of things, the most common would be for you to be using an auto AF point selection mode and the camera is picking up and focusing on the white lines in front of the car. Another, but, seemingly less likely in this case would be that your lenses need micro focus adjustment on your 80D. I'm guessing it is understanding the more complex AF system of the 80D that is giving you issues rather than a problem with the AF system that needs adjustment.
10-27-2017 12:24 PM
10-27-2017 12:51 PM
If you are getting sharp images in LiveView but unsharp through viewfinder with more than one lens it is very likely a camera problem. LiveView focuses right on the sensor. The viewfinder uses an indirect ethod of focusing (as discussed in the links).
It should be sent back.
10-27-2017 12:38 PM
10-27-2017 01:02 PM
10-28-2017 12:47 PM
@KevinG1 wrote:
Thanks for the help! Im really struggling with this camera, and feel like it shouldn't be this difficult to use
Be sure you watch those videos on Auto Focus they might explain some of your difficulty.
Your camera's PDAF system may need factory calibration. The problem is your statement that you 'tried MFA and it made it worse' indicates a user issue not a camera issue. The thing is even if it does following the directions in Canon's Micro Focus Adjustment guidebook should make it better. If you use MFA and make it better, but, it is beyond the range of MFA to make it 'perfect' your camera needs a trip to Canon. If you use MFA and it requires a +/- 15-20 adjustment to make it perfect you still might consider sending it to Canon.
