10-26-2017 10:05 PM
10-30-2017 06:36 PM
@KevinG1 wrote:
Gotcha. Ill just need to shoot more and see what methods work best for me.
Also i did a micro af adjustment and found my canon 50mm 1.4 was off a bit. Definitely wasn't helping me
I suggest that you reset your AFMA back to zero, until you gain more experience with the camera. Learn how to half press the shutter when using One Shot mode, so that you can evaluate the AF points.
When you have all AF points active, like [A} mode, you may see multiple AF points light up. Be aware of the fact that the camera is indicating which AF points are capable of achieving a focus lock, but only one AF point will actually be used to focus the shot. The automatically selected AF point will typically rest on the closest object under an active AF point.
It is highly recommended that you configure the camera to always use the center AF point, which is the most sensitive and accurate AF point. And, always use One Shot focusing mode, until you gain more experience using the camera to focus on the subject that you want.
One final note. The AF points are actually slightly larger than the red boxes you see in the viewfinder. Placing an AF point on something may not always focus where you want it to. The camera will focus on the highest contrast area that it can find within the AF point coverage area. So aim your camera at vertical and horizontal contrasting lines.
11-21-2017 05:25 PM
I will be looking forwaed to your report. I hope all is well for you.
11-22-2017 12:45 PM
11-22-2017 08:30 PM
@KevinG1 wrote:
Not sure what else to do
Stop pixel peeping and shooting test shots.
Go out and take real world pictures, make some prints and enjoy your camera.
01-30-2018 03:15 PM
I bought a new Canon 80D in October of 2016. I told the shop I was having trouble with it but over an hours drive. finally went to one of their classes.. 20% (if that) are perfect pictures but the rest are all blurry.. I love being out with my camera. Love taking pictures of other families when asked but started thinking it was me.. Then my daughter used it and does a lot of photography and they were blurred for her also.. Just had it sent it and after three weeks it is back and I think that it is worse. I am so upset about this camera so don't think it is you
01-30-2018 03:55 PM
01-30-2018 05:39 PM
01-30-2018 07:41 PM
@KevinG1 wrote:
Easiest way to test it. Take 2 photos, exactly the same settings, but one using live view, and one using the view finder. If there not the same, then you need to do a afma with the lenses.
I sent my 80d in, and didnt seem like it got any better, so I returned it. Been using a 6d and have not had any problems
Lenses focus at the maximum aperture, which a given lens is capable of. When you fire the shutter, the lens stops the aperture down to your exposure setting. Using an f/2.8 lens causes high end cameras to focus faster, and sharper, with certain AF points because the AF sensor is receiving more light. The center AF point is almost always the best AF point to use as a starting point.
If you are shooting a still subject, then use One Shot mode with Evaluative Metering, which should be the default settings from the factory. Only use AI Servo mode if the subject distance to the camera is changing, and only then if the distance change exceeds your depth of field of your aperture setting. I like to use a stopped down aperture with AI Servo, f/5.6 to f/8. Remember, though, the lens will focus at maximum available aperture. I rarely us DOF preview, so I disable it.
01-30-2018 07:59 PM
I wish I could send this camera back but it has been a year of trying to figure out what I was doing wrong!
04-01-2020 05:26 PM
