10-13-2013 09:50 PM
Can we record to both the CF and the SD cards at the same time on our 5D3 cameras?
I thought we could, and I set up the camera's menu to:
Record Func. = Rec to multiple
Playback = [2]
But when I record a clip, it ONLY seems to record to where I have the "Playback" pointed.
Is that Record to Multiple ONLY for still images?
10-13-2013 10:11 PM - edited 10-13-2013 10:12 PM
Haven't shot a 5D3 but the cameras I do use need to be set to BACKUP and then you set which files go to the cards (both, Raw card X & jpg to card Y or the reverse).
10-17-2013 03:38 AM
Almost 100 views, but no answers. I'd have thought this, being the Canon site, I'd have had a quick Reply here from someone.
Any suggestions where I should pose my query that I might get an answer soon? I have an upcoming shoot, so I'd like to solve this ASAP.
Thanks!
10-17-2013 12:13 PM
@mjroddy wrote:Almost 100 views, but no answers. I'd have thought this, being the Canon site, I'd have had a quick Reply here from someone.
Thanks!
Most people on here shoot stills. Not that there aren't videographers, but most of the regulars seem to be on the stills side. That probably has something to do with the low response.
I'd recommend posting on CanonRumors.com. Lots of very knowledgeable people there; and no shortage of 5d3 owners. Post to this Forum:
http://www.canonrumors.com/forum/index.php?board=47.0
10-17-2013 12:36 PM
01-07-2014 01:50 PM
01-07-2014 02:50 PM
This does seem to be a more 'stills' site than a video site. So I asked my videographer bud about it and he said......
You can select which card movies will be recorded to, but there is no overflow or mirroring capability
for movies with the 5d Mk III.
01-07-2014 02:59 PM
This is, unfortunately, what I've found too: NO way to mirror video footage in-camera. Some newer cameras do this, but not our beloved 5D3.
01-07-2014 03:17 PM
01-07-2014 03:28 PM
Agreed.
I was SO burned by some VERY high-end cards that I'm no a little "freaked out" shooting with the camera (onto CF cards).
One practice I was told to use is to (for CF cards) format the card first in your computer, then again in your camera just before use.
I've done this and so far, I've had much better results. Not FLAWLESS, but MUUUUUCH better (I was really burned).
Hope that helps a bit...
