05-29-2013 03:42 AM - last edited on 05-29-2013 08:39 AM by Stephen
I have a Canon 6D, a canon 430ex II and a set of Phottix Ares transmitter and receiver. I have set up my flash off camera and was planning to use the camera’s wifi capability to take a self portrait with my iPhone EOS remote app, but the flash wouldn't fire at all. When I turned off the app and phisically pressed the shutter it worked but never through the app. Then I thought of mounting the 430 directly onto the camera, used the remote app to shoot wirelessly and I was surprised that it worked!!! I coudn't find the logic behind this and I tried to find an answer everywhere with no hope!
Has anyone gone through tha same experience or have any explanation or solution to this problem? or any alternative solution to get the flash to trigger while shooting wirelessly? thanks.
[Mod note: Moved to "EOS" because issue seems to be with the EOS App. You'll get more exposure here!]
05-29-2013 11:38 AM - edited 05-29-2013 11:38 AM
If you are shooting using Live View (through the app) it won't fire the flashes like that. But if you just use the app to release the shutter and review the pics it will. It's been awhile since I've used the app, but there's a button or something to go between live view and standard shooting.
That said, I've read that some cameras can work around this by going into the menu and disabling silent shooting, and then Live View will work with simple triggers. I've never done it as I don't shoot in live view, but I've seen this discussed a lot. Not sure if the same can be said for the app, but it's worth a shot (no pun intended).
http://www.p4pictures.com/2011/02/live-view-mode-and-flash-on-your-eos-dslr/
05-29-2013 02:37 PM
05-29-2013 03:41 PM
Glad I could help.
@Samhark wrote:
The only thing that confused me at first was that the ex430 has worked when mounted even with live view; still confusing though!
If you're talking about on-camera flash, I believe that Canon brand flashes will work in Live View when mounted. The problem is if using the radio triggers then it doesn't matter what brand the flash is, it just sees a generic device.
Give the silent shooting workaround a try (you have to disable it through the menu, not the drive button). I've been curious to try it myself just to see, but never really have a use for Live View when using off-camera flash so I never think about it.
