10-29-2015 01:47 PM
How do I save an image from Photoshop so I can transfer it back to the 70D?
I am trying to use Photoshop to modify a picture I took with the 70D and then transfer that modified picture back to the 70D. I am using ImageBrowser Ex and the problem is that when I select that modified image and try to Transfer it, ImageBrowser Ex tells me that "A still image that cannot be displayed on the camera has been selected."
I have simplified the problem by just opening the original image file and immediately saving it to a new file without changing anything but even that "unmodified" file fails. Apparently, Photoshop is changing something when it does the Saves As but I can't see what the problem is.
Note that I have also tried just using Windows to manually copy the Save As file to the memory card but the picture doesn't appear in the "Picture Preview" when I put the card back in the EOS 70D. This also happens if I copy the original image file to the card. I suspect the problem is that the EOS 70D has some sort of "file index" that isn't updated with info about these files if they are just manually copied to the card.
Can someone please tell me how to Save As out of Photoshop so I can transfer the new file back to the 70D using ImageBrowser Ex?
Thank you.
10-30-2015 11:28 AM
It may help if you apply a sticker to the camera body and/or a luggage tag on the camera bag, etc. that includes the words "Reward if found & returned" with your phone number attached.
10-30-2015 07:35 PM
I have one of these tiny little guys threaded onto my strap to keep memory cards in so I don't ever have to carry my backpack just to have a couple of 1-gram memory cards handy.
I can't believe I have never until just now thought to put a tiny piece of paper in there with my name, phone number, etc., but I am going to do so.
http://www.bhphotovideo.com/c/product/289678-REG/OP_TECH_USA_4701002_Media_Holster_Pack_of.html
10-31-2015 10:25 AM
Hi AlKoch!
I don't usually step in on these kinds of posts, but I wanted to give my two cents.
The one thing that I think that *could* be happening in your case is that our cameras simply won't recognize images that have been modified in any way, including cropping outside of the exact dimensions the camera takes or if the image has been rotated by any software including your computer operating system. Another user pointed out earlier that this happened to them when they cropped, but we see it happen all the time when people take their cards out and Windows (usually) rotates their portrait oriented photos to landscape and then they put the card back into the camera and they get an error message.
While the camera is a tiny computer in a sense, it's not designed to recognize anything except the images it produces. If it sees something unexpected it just doesn't know how to react. Zoombrowser is trying to help reduce the error messages by preventing you from being able to transfer altered images back to the camera.
All of this to say - if you have an alternate device like a tablet, laptop, or a even a smartphone on which to showcase your edited photos, that's the route most people go these days. They all have bigger screens usually and photo viewers that won't have any problems with your edited work!
We hope this helps!
10-31-2015 12:38 PM
"The camera dose not display the image on the SD card per say. It makes a thumbnail and I don't know if it will do that if it didn't actually take the picture."
What you modify does not compare to the thumbnail the camera makes. What I am not aware of is whether the camera re-constructs the thumbnail each time, I doubt it, or uses one it makes at the time the photo is taken. Example, a RAW image can not be displayed unless a jpg thimbnail is created by the camera. No matter it is this thumbnail you are viewing on the camera LCD. In this case, thumbnail means the camera's opinion of what the photo looks like. It is another reason why "chimping" to see if you have the correct exposure, etc, is a no go idea.
The solution is simply, just print it and take a photo of what you want. No fuss, no bother. The the whys and wherefores are not even a consideration.
