11-04-2013 03:37 PM
My son is taking my 7D with him on his attempt to be the first to bike to the South Pole. What do I need to do to prepare the 7D for extreme cold?
11-05-2013 06:40 PM
As I said, point and shoot in the inside pocket. I don't know much about Antarctica exploration, but I can tell you what works for high elevation mountaineering, which seems to share a lot of the same issues. Size and weight are primary concerns. There will be plenty of light in Antarctica when he’s there, and not much is moving, so a point and shoot will do just fine for quality. Weather sealing means nothing in that situation; if you can’t keep it next to the skin it won’t matter anyway. An SLR is impractical unless you’re doing serious photography/video, in which case you’re going to have support. Keep it in your inside pocket with the battery reversed inbetween use, and keep extra batteries. It works up past 26,000 feet, it should work down south. Be cognizant of button size when selecting a camera, you’ll have large gloves on. I’d buy a camera to fit my use, the cost of a point and shoot is trivial to the cost of an expedition to Antarctica. Learn how to turn off the preview screen, that will eat up batteries. A lightweight solar panel can trickle charge if need be, they can just drape over your backpack, you don’t even notice. Don’t use flash, way too much juice.
Although film cameras don’t require the electronics, the film doesn’t care for static electricity. There’s plenty in the dry air at elevation, not sure if that’s an issue down south or not.
11-05-2013 07:06 PM
According to the blog he'll have solar charging equipment for his sat phones / emergency equipment.
11-05-2013 07:29 PM
Got it, sorry, wasn't able to read the blog through this firewall.
11-05-2013 07:36 PM - edited 11-05-2013 07:37 PM
It's a pretty ambitious undertaking. From what I read he's going solo for the entire ride to & from the pole using a mountain bike with 4" wide tires, saddlebags & I think pulling a sled with supplies. There will be supplies dropped off in 3 locations along the intended route plus at the ploe.
11-06-2013 12:26 AM
I really appreciate all the suggestions. My first job after graduate school was at the University of Alaska at Fairbanks (as a Marine biologist). I know first hand how difficult it is to do even simple things at -55 degrees F. This was in 1964 and we used simple 35 mm film cameras. My friend did considerable work at the South Pole and even through he has been retired for 20+ years, I wrote him to see if he knew anyone currently doing work there and what they used for cameras. Here is his reply
11-06-2013 07:38 AM
I suggest that you join this forum & post in the appropriate sections (Canon gear, Nature & Wildlife or any other where trips to the far north or south would be common. There are a lot of very skilled & well travelled members from around the world.
http://www.fredmiranda.com/forum/
I have also got a simple test you can run on your camera & lens. Bag it up & place it in the freezer for a couple of days without the battery . You'll need to keep it from forming condensation before it cools down so that's the purpose of the bagging. My interpretation of his journey is that he won't have any way to protect it from the cold while travelling, & therefore it will be nearly impossible to keep it from getting very cold by days end & just as difficult to warm it overnight while sleeping.
Normal expeditions have vehicles, huts etc where things can be kept warmer than the outdoor temp allowing on & off use in the cold & then back into the warmer air.
11-06-2013 07:48 AM
Forgot to add this re the differences between film SLR's & DSLR's which would be where I think the DSLR will fail. It contains too many electro mechanical devices and each has a design limit on how much power it can consume to do it's job. If something hangs up (in this case because it too tight from contraction or thickened lube etc) the camera will shut down & give an error code instead of supplying more power (amps) to the component. Mechanical film cameras & lenses didn't have this potential problem & relied on springs, levers etc.
I long ago got rid of all my photography magazines or I'd search the house for the article but it was rather lengthy & it said National Geographic had it's own department who did the work & from memory everything was torn down & modified lubed etc as necessary & I'd bet some of it was learned as the result of failures in the field.
11-06-2013 11:49 AM
Thanks everyone! I've got to get something ordered today, Daniel is leaving next week. I'll keep you posted.
Here is a news spot on his trip.
11-12-2013 11:41 AM
Tamron support sent the following. The link to additional information is useful. Daniel leaves this Friday for Chile from which he will leave for Antarctica. He is taking the Canon 7D, a 10-24 zoom lens, a 28-135 zoom lens, a Canon G16 and a Sony video camera. I will keep everyone posted as to how everything works.
Thank you for contacting Tamron. Unfortunately are lenses are not made to withstand temperatures that low. At extreme sub 0 temperatures the lens could contract and completely seize up. There are some companies that sell lens blankets to protect lenses from moisture and the elements but I think he would need a heating blanket of some kind. I don’t know of any brands but I have heard of cinematographers using lens heating blankets in these environments. I found this article on cold weather photography that may be of some help: http://photography.about.com/od/takingpictures/a/coldweathrphoto.htm
Should you have any other questions please ask.
Kind regards,
Brian Marley
11-12-2013 05:35 PM
I'll be quite interested in how it goes. Not one bit surprised with Tamron's answer.
