01-09-2017 12:49 PM
I can see the histogram in Live View but not through the viewfinder when I come out of Live view. Repeated pressing of info button provides no results.
01-09-2017 01:20 PM - edited 01-09-2017 01:21 PM
@chrismurdoch wrote:I can see the histogram in Live View but not through the viewfinder when I come out of Live view. Repeated pressing of info button provides no results.
You shouldn't see a histogram display in the viewfindeer. A hiistogram is a detailed analysis of an image. The image sensor is used to sample the images for analysis. When you use Live View, the mirror fips up to expose the image sensor, and the viewfinder blanks out. You will see an image on the LCD.
The opposite happens when you look through the viewfinder. The mirror is down, and the LCD image is blanked out. This means that the image sensor is not being exposed, so no analysis can be performed.
01-09-2017 01:22 PM
In other words, the 70D does not have an EVF, just a straight (well, not *straight* ...) optical path to the lens
01-10-2017 04:51 AM
Does that mean I can only check exposure in live view or after I have already taken the shot?
01-10-2017 05:15 AM
