EOS 1D MKIV and SDXC Cards
mgrabow
I have a 1D MKIV and it will not read a 64GB SDXC UHS-1 Card.   Is there a limitation on the camera on the size?   I need the high spead because the slower ones are causing me to lose shots when I am rapid firing...It also will not format it...
4 REPLIES 4
cicopo
I don't think it can recognize SDXC cards. That type of card wasn't available when the camera was designed / built & unless Canon can write firmware to recognize it using the existing electronics in the camera you'll need to buy something else. I've had good write time using Sandisk Extreme Pro cards which meet the SDHC classification. I think the write speed is about 90 mpbs but there is an even newer version that's faster BUT MAY NOT WORK in the 1D4
Unfortunately canon seems to have dumped the mark 4 in favor of the x and the c.... They even discontinued the wifi adaptor...they need to we write the firmware to bring these up to date...
Firmware would not fix this problem. Smiley Sad
Dun1
Here is a link to the Sandisk website, if you plug in your camera model it will give you a list of the Sandisk Memory cards that are compatiable with your camera body
     http://pct1.sandisk.com/NewSearch.aspx
Enter for a chance to win!
April 20th-28th
