Reply
New Contributor
Confusion about 6d mkii headphone jack
I'm confused about something I just read on the CanonUSA website.
I'm planning on buying the new 6d mkii, but I've been bummed about the lack of a headphone jack, since I also shoot video. I was just reading some info on the Canon website, and it referred to a "headphone terminal." What the heck? What is a headphone terminal? Is a headhphone terminal the same as a headphone jack?
Maybe someone from Canon can clear this up for me.
Thanks,
Ross
aka @oldguywithacamera
Esteemed Contributor
Re: Confusion about 6d mkii headphone jack
http://gdlp01.c-wss.com/gds/3/0300027473/01/eos6d-mk2-bim-en.pdf
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472
New Contributor
Thanks for the page from the manual. I'm guessing that by "headphone terminal" they're referring either to the USB port or the HDMI port. I'm planning on mounting a small LED monitor in the camera's hotshoe, and then taking a headphone feed off of there. Maybe there is a way of getting audio off that usb port.
Hello OldGuy,
The EOS 6D Mark II doesn't feature a headphone output through the terminals.  The methods I've seen for monitoring are to use a third party device, such as a microphone recorder or like you mentioned, an HDMI monitor with a headphone out.  I think the idea being that if the audio is crucial enough to monitor with a headphone then you're probably using a more advanced audio setup with a seperate recorder and microphone/s which would make monitoring via headphone easy.
New Contributor
Thanks for your comment. I think that may be the "idea," but it was a really bad idea. Microphone jacks aren't high tech. They should have put one in. They cost about ten cents.
They have a microphone jack.
The cost (and space!) is in the amplifier, not the jack.
powered by Lithium
