Reply
Esteemed Contributor
Re: Color Problem with 5D Mark 3
ebiggs1 wrote:
OK, here we go.  This isn't as intimidating as it may first sound to be.  So, keep cool.  There are only a few things you need to consider but they are extremely important.  Again, you are going to hear from the "holier than thou" guys but here it is in a nutshell.  You don't need any fancy extra add-on to do this.  No additional software or gadgets, etc.  No monkeys, no spiders, nothing!  Most people set their monitors too bright.  You must get the gray-scale very close.  You need to get the brightness very close and you need the contrast very close.  If you are on a Windows machine the needed adjustment ability is included.  I am not a Mac user but I am sure it has the same feature.
Depending on your Window version go into the monitor settings. On Win 10 it is called Display Settings.  From there just follow the instructions.
It's easy to do, but I've done it manually... and the results weren't good.  Apple also has a manual calibration wizard that walks you through the tweaks.  They display images on the screen and ask you to tweak adjustments to get certain results.  If you follow the steps then what you should have is a semi-decent calibration (it wont be accurate, but shouldn't be horribly off).  I found that what I was able to get by eye-balling it was still off enough that I was getting the noticely poor results (they looked good on my display, but other photgoraphers reported they were much too orange.)
The hardware tools have various capabilities and you pay more for the tools with more capabilites.  Very high end calibration tools can be expensive.  There are some devices that can cost a few hundred dollars (there are even versions that cost thousands)  ... but these not only calibrate your displays, they can calibrate your printers (including inks & paper variations), as well as projection screens.  You probably don't need to calibrate a projection screen.  If you send out your work for printing (becuase printing your own can be expensive in ink costs) then you don't even need to calibrate the printer.
So there are versions that _only_ calibrate displays.  Those devices are priced a bit more reasonably.  An X-Rite Colormunki Display is about $150-160.  The DataColor Spyder 5 Pro is similarly featured and priced (about $150-160).  But DataColor makes a cheaper version with even fewer frills for about $120 called the Spyder 5 Express.   These devices only calibrate displays (laptop screens & desktop monitors.)
The devices are very easy to use.  You install the software, plug in the calibration device (USB) and place on your monitor.  It will have your graphics card cycle through lots of colors and each at different brightness levels and comapre the sampled color to what it should read if the monitor is accurately calibrated.   It uses this to build a monitor calibration profile which will cause your graphics card to alter colors to match the calibrated color so that what you see is accurate.  Once it's done, it activates the color profile for you and you can trust your display again (you don't need to do anyting to any other software you use... just use the computer normally.)
There are numerous YouTube videos that show you how they work.
A color-managed workflow should also include a decent gray-card (those are cheap).  Take shot of the gray card in the same light that your subject will be shot in.  That single image of the gray card can be used to set the white balance accurately for every other image you take (as long as they were shot in the same lighting.  If you change the lighting or location then you'd wnat to take another gray-card image.)
If you're just shooting for your own personal use then I wouldn't worry too much about accurate color.  If the color is good for your purposes, then it's probably good enough.
If you're shooting professionally, then I feel that any professional owes it to their clients to provide accurate color in the images (because color that only looks right on your diplay... but not on other displays, can mean that the client is getting poor results).   If you were doing product photography where consumers choose products based on color (I want this shirt in a certain color) then that color really has to be nailed bang-on accurate.  It's easy to do that with a color-managed workflow.
LED monitors have very little color drift over time.   LCD monitors that use a florescent back-light (that woudl have been very common around 2000) will have more noticeable color drift over time because the color temperature of the light source will change as it gets older.
Tim Campbell
5D III, 5D IV, 60Da
Occasional Contributor
I just don't think it's a monitor issue. My photos always look the same as they do on the computer... whether it be through print, or on others' mobile devices, etc.
I think the problem is my eyes/brain. I think, at this point, I'm just being nitpicky. But I was SOOOO used to the Mark II... Making the adjustment to the Mark III has been more challenging than I believed it would be.
VIP
Shouldn't be. There is no reason why.
What tim campbell says is true for labs but all most of my clients ever were concerned with was flesh tones.
Set your monitor like i suggested and you will be fine.
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
This is a photo I took about 2 days after the ones of the child in the chair. I'm just now getting around to editing these.. This is a JPEG (.... tweaked a little in RAW, added a RadLab action and saved as JPEG so you could see)
Do you guys think THIS one have a green tint/tone?
*and yes.. it was cloudy on this day, too...
*and yes... I even bumped the magenta slider in ACR, trying to stay away from the green tint...
I see it as a bit on the orange/brown side. Try doing a "click white balance" on one of the white squares in the man's shirt.
Bob
Boston, Massachusetts USA
VIP
"Do you guys think THIS one have a green tint/tone?"
Of course it has a green tone.  The photo is mostly ... green.  This photo confirms what I told you.  It is the flesh tones.  That is what people care about.  If you intend to do this for a living or at least sell your work, you need to learn that quickly.  People look at the faces in this type photography.
Do this for me, set your monitor up as I suggested and work on the flesh tones.  If you want to choose withe or grey or black areas in the photo to set the grey-scale, OK, just as long as the skin looks right !
I'm detecting the uncertainy ... you tink it seems a bit green but you'd like our opinions.
Opinions are subjective... that's why they are opinions.  But there is a objective, scientific way to absolutely nail the color balance every time with no guesswork and it's actually pretty easy.
Just use a gray card whenever you care about accurate color.
There are a LOT of YouTube videos that demonstrate how to do this.  Gray cards are pretty cheap.  Some are as cheap as a few dollors.  Some high quality ones (large, waterproof, collapsible, etc.) might cost the better part of $50 but that's really on the high side... most are much much cheaper.  You can even use a white sheet of paper provided it actually is "white" and you don't over-expose it.
Having said all this... sometimes I don't want accurate color.  If I'm shooting a candle light scene... or a sunset, the color of the light is going to be tinted by the light source (such as the setting sun) and we want it to be colored.  I wouldn't want to white-balance a sunset because that would ruin the whole point of the sunset.
I have shot on cloudy days (because the light doesn't have harsh shadows) but deliberately bumped up the color temperature so that it doesn't look like a cloudy day.  Having the ability to find the perfect white balance is just a data-point for me... but sometimes I want to adjust it away from a perfect balance based on the mood of the image.
Tim Campbell
5D III, 5D IV, 60Da
Hello, all! Back again with the latest update...
FINALLY got a chance to do a side-by-side comparison.
Let me preface this by saying that my reasoning behind buying the Canon 5DMark III was a bit of a story in itself. I have had my Canon 5D Mark II for about 1-2 years now.. and even though I have LOVED it, I have noticed that if I go any wider than a 2.2 aperture, the focus seems to be very unreliable. Sometimes, it would hit. But more often than not, it would miss. (And it wasn't just my Mark II - I had even rented one a time or two, and it did the same thing.)
After a lot of time struggling with what might be causing it, I decided I might need a different lens than the 50mm 1.4 that I've been using. That was... until a friend pointed out that her Mark II had the same issue with unreliable focus at a wide aperture. She explained that the Mark III hit focus dead-on every single time. So, of course, I tried it.. and after seeing such a vast improvement in focus, I made the purchase of the Mark III. I never noticed the color issue until I shot outdoor portraits with it for the very first time.
Here is a side-by-side comparison... Speaking frankly, the 5D Mark II shot is probably a little out-of-focus... but I think the green shirt on the kid, and the green background, really showcase the difference in color between the two cameras.
(Sidenote: I even borrowed my friend's 6D to compare with today, but the focus on it was pretty unreliable, also. And even though the color is similar to the Mark 2, I honestly feel like I would rather claw my eyes out over color, than focus.)
PLEASE NOTE: I had set custom WB to 7300 for BOTH cameras while shooting today, but when they pop up in ACR, the WB has changed on its own.
*providing links because inserting images was making my post disappear, somehow*
Canon 5D Mark II: https://ibb.co/gAq1jF
Canon 5D Mark III: https://ibb.co/nbDMjF
I noticed the color temperature and tint was changed between the two images (looking at your adjustment controls on the right).
I wish I had non-adjusted original data.  Can you convert your CR2 files into a 16-bit tiff but give us straight-out-of-the-camera shots to compare?
I'm using my digital color meter on the images and checking the center of the subjects forhead as well as the cheek just to the right of the block spot.
The blue-channel values seem to be similar.  The green channel is moderately boosted ... but the red channel is more significantly boosted.
Something else... you're taking a photo that's LOADED with greenery everywhere.  The grass, the trees, etc.   Can you "see" the mostly green surroundings with your eyeball?  That's because green light is bouncing off those background elements and traveling toward you.  It's not just hitting your eyeball and your camera lens.. it's hitting your subject.  Your "light" will have a color cast based on the dominating colors in your surroundings.  This is why we use gray cards to calibrate the image.
When I toggle between the two images and just look at the histogram, I can see the histogram is spread more broadly on the 5D III (but then you didn't use the same background so that might explain it.  And possibly subtle variances in light level since the subject isn't in sunlight.)
You're not collecting good comparable data.  Ideally you'd photograph a gray card in identical light with identical background (and I do mean IDENTICAL... not merelely similar enough that most people wouldn't fuss over it) and taken at the same time in IDENTICAL light (again... if clouds are moving in and out and brightness is varying... you've invalidated the test.)
In order to isolate the difference between cameras, you have to make sure there are zero difference between the subject (not just very little difference... it most be none, zero, nada, zilch.)
Otherwise you can fall into the trap of "selective data" (using examples that support your hypothesis and ignoring the examples that contradict your hypothesis.)
I know it sounds like I'm beeing fussy... but I've seen a lot of people show up with similar types of questions over the years and it's like pulling teeth to get people to do a legitimate test and there are simply too many things that can explain the difference that would not be based on the camera.
They are different camera models so we would expect some difference.
Color is so very easy to manipulate that I never give it a second thought.  I just use a gray card... problem solved.  It might cost all of $10 (what else is in your camera bag that costs so little).    For $20 you'll quite a rather nice gray card.   Click the "white balance" eye-dropper then click the gray card, and all color descrepancies are neutralized that fast... you can enjoy your improved focus system and still know that you're nailing the color accuracy.  If you prefer warmer colors than true-accurate color (go to any art gallery that sells photos for high-$$$$$ and notice that saturation sells.  It may not be accurate, but people seem to love it.)  You can make any camera give you any color results you want.
Tim Campbell
5D III, 5D IV, 60Da
I don't know why the temp & tint change themselves.. I had both of them set to 7300K, I believe, but it would appear I'm shooting at 2 different WB's. And I'm afraid that might be part of the problem.
I don't know how to convert a CR2 to a 16-bit TIFF, but I'm willing to try.
With your naked eye, you can't tell a difference between the two images? I purposely put him in a lot of greenery (although, I did not know he was going to wear a green shirt). But my point in that was... my Mark 2 would have easily responded to all of the green very well, and handled it like a champ. However, my Mark 3... that's just not happening.
I will say, though, the background is identical. We stayed in this little 10-ft area of the yard. It might just be zoomed in, or panned to the left, or what have you.
I'm on my way out the door to take some more test shots, both WITH a WB tool and without. (I have the ExpoDisc.)
powered by Lithium
