03-02-2017 11:34 AM - edited 03-02-2017 11:42 AM
Hi there,
I'm new to the forum so thanks in advance. My question pertains to video/vlogging only, (no stills).
I'm currently using a 70D for vlogging, but it's fairly heavy and also doesn't have any in-camera stabilization.
I'm wondering, if I got an EOS M5 (or M6 in april) which have in-camera 5-axis stabilization, could I also just get an EF-M to EF mount adapter, throw a nice fast L-series lens on there, and get a super crisp (but ALSO stabilized) image? Best of both worlds so to speak?
Thanks!
-Nick
03-02-2017 12:57 PM
@nickfoxer wrote:Hi there,
Thanks!
-Nick
Sure, you could try that. Although, I would strongly advise against it because the battery is just simply too small. Canon even beefed up the battery, too. Instead of 150-200 shots with an EF-M series lens, you should now get 250-300 shots.
Bear in mind that those numbers [told hold me to them too closely, please] are with EF-M lenses, with much smaller focusing motors and much lighter lens elements than standard EF/EF-S lenses, much less "L" Series lenses.
I have an M3 with the adapter. The only EF lenses that I have used on it are the two pancake lenses by Canon. Most of the time I have a manual focus Rokinon 14mm lens mounted to it. The M Series is great for manually focused shots. Due to the small size of the batteries, you would be limited to what you could do.
I have never shot video with it. It is great for manual focusing scenarios, like macro shots. It is also great for using a wide angle lens focused to the hyperfocal distance, and shooting landscapes and cityscapes. I also put a pancake lens on it, and hand it to someone who wants to tag along when i go shooting.
03-02-2017 01:52 PM
Hey thanks Wadizzle!
So are you saying that the M5 isn't good for shooting video in general? Because of the limited battery life? Or that attaching an EF lens will drain the battery extra quickly?
03-02-2017 02:18 PM
@nickfoxer wrote:Hey thanks Wadizzle!
I can only speak for the M3, because that is the camera that I own. I have never tried to shoot video with it because of the small battery. The battery in M3 has just enough capacity for an amateur to go out and shoot pictures for an hour, or so, using the EF-M lenses, which are quite small, BTW.
I have used the "nifty fifty" with the M3, and it was half drained after some 50 shots, or so. An L"L would only be far worse. If you plan to use EF-M lenses, then the M Series cameras are probably pretty good shooting short video clips. Just don't expect to put in a full day shoot with one.
Right now, I think the best buy in the Canon consumer lineup is the 80D, which excels at shooting video.
03-02-2017 02:42 PM
Gotcha, thanks so much for your help Wadizzle! I knew I'd get a great answer on here 🙂
03-03-2017 05:38 AM
03-03-2017 11:28 AM
Awesome, thanks Peter! 🙂
