Reply
Occasional Contributor
Canon EOS 1000D problem buSY
[ Edited ]
Hello my frends,
I have EOS 1000D and big problem with DSLR.
Cant boot on power on. When I put fully charged battery, close batt. door, RED LED blink fast 1-2 sec and thats all. LCD display is black and stay black. When I press shutter to half or full, I can see tru viewfinder buSY message , ISO change value on light and thats all. When I put LOCKED SD Card, tru viewfinder I can see Err. , when I put  unlocked SD Card ..still buSY. Shutter have no responde
 USB to PC = not detected!
Reputable Contributor
Re: Canon EOS 1000D problem buSY
There is a firmware bug with 1000D that forever will lock the camera.
My Swedish blog
M5, 7D, 6D, D30, 1000D IR, 16-35/4L IS, 100/2,8 Macro, 70-200/2,8L IS II, 24-105/4L, 85/1,8, 50/1,4, 24/1,4L II, 300/2,8L IS, Helios 58/2
Darktable, RawTherapee, Photomatix, Luminance HDR, GIMP 2.9.5.
I see Smiley Sad Anyone can unbrick? JTAG, USB,... or ect. ...? Maybe bootable SD card..?
Respected Contributor
bokacbl wrote:
Hello my frends,
Try a different card preferably a new name brand SD or SDHC card. Do not use an SDXC card.
Same problem with or without SD Card. Must power on without card?!
Moderator
We found that often what caused this was not updating to the most recent firmware.
If your camera became affected by this phenomenon, while the camera was still in service life (up until 2015), our Factory Service Centers here in the United States could still manually upate the firmware. Unfortunately the camera is now out of service life, so our facilities here in the US are no longer making repairs or updates to the EOS 1000D, or Rebel XS as it is known here in the US.
Tnx for answer! God bless you!
Actually, I'm not from the USA. I am from Bosnia and Herzegovina, Europe. Here I do not have a good service for DSLR. Is there a chance to flash a new firmware? OverSD Card or serial cable? Tank you
Moderator
If your camera can be recognized by your compuer, then you should be able to update the firmware. If your camera can't be seen by the computer, then unfortunately you'll want to see if Canon in your region has options. Head to http://global.canon/en/support and select your region for support options.
F5
Ha. I'm going to start using the word "phenomenon" when I totally screw something up at work.  Like the curious phenomenon where it appears I do not show up, and instead I am actually at home sleeping.
Seems warranty or no, he should at least get loyalty credits towards a refurb or something because it didn't wear out, it is a known defect.
Scott
powered by Lithium
