03-09-2017 03:27 AM
03-09-2017 04:06 AM
03-09-2017 04:24 AM
03-09-2017 06:51 AM
It is almost impossible that the sensor has moved out of position. It is more likely to be a fault with the mirror or focus screen assembly. It could even be the shutter cutting off one side.
Do you get the same problem in live view ?
03-09-2017 01:13 PM
I would take a picture of a brick wall with some post-its to provide some reference points to the outside of the image. Then use the center focus point to know *exactly* where the center of the image is and what is shown in the viewfinder.
03-09-2017 12:41 PM
@Rushj wrote:
Hi everyone,
I bought this body some years ago and have noticed that I'm not getting the picture I see through the view finder.
For example if I take a centered group shot, the image will be off centre.
It may not be actually cropping but could just be taking an off centre picture to what I'm seeing in the view finder. Usually it appears to crop on the left so I have to shoot wider or more to the left to compensate.
Any ideas? From searches I'm guessing this isn't normal. Thanks
Do you wear glasses? Then I think I know the answer, because it happens to me if I'm not very careful. Because I can't get my eye close enough to the eyepiece, the angle between my face and the camera matters. Because the right lens of my glasses keeps the camera's left side more distant, I'm effectively looking to the left. Which means I don't see, or take into account, the right-hand end of the frame. In the resulting picture, the subject appears displaced to the left.
Even if you don't wear glasses, your nose could have some of the same effect. Be sure that you're seeing the entire frame.
03-09-2017 04:49 PM
I am going to go with Robert's answer. The other suggestions are impossible and still get you a focused picture. Be more conscious of how you frame and look through the VF.
03-10-2017 03:30 PM
03-10-2017 06:04 PM
03-10-2017 06:15 PM
@Rushj wrote:
Hi guys, no I don't wear glasses and this is over a long period of time and in every shot.
It's like I lose a fifth of the frame from the left. I.e. Out of alignment. Same on various lenses.
Will try live view as someone suggested though as that would remove the mirror from the situation. If it's ok in live view then it must be the viewfinder alignment/mirror.
If it is okay in Live View, then there is no misalignment of the lens mount, such as from a camera drop. The issue not showing up in Live View would suggest that your issue is directly related to the viewfinder. It could be your angle of observation. It could be the mirror is misaligned. It could be something else entirely, like the eyecup or something.
How a mirror could be come misaligned is another matter. An attempt to clean the mirror box, without being aware of just how delicate and precisely aligned all of the componenets are is one explanation. The mirror really shouldn't misalign itself without being acted upon by an external force. Then again, hundreds of thousands of shots just might do it, too.
Can you post a shot of the problem?
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
