12-08-2017 07:22 PM
I have not needed the experienced advice of this forum for several months because your previous advice/help was so very useful. However, I have run into a bit of a issue pertaining to the Shooting Modes of my 1DX MKII.
I have a pretty good working understanding of the Manual Shooting Mode. I am able / need to manually set the Apature, Shutter Speed and IOS when in Manual Mode Setting. I am certainly able to do this, but it can be a bit cumbersom and too slow in some shooting settings.
Setting my camera to, APATURE Priority Mode, allows/forces me to select and set the desired Apature setting, however, I can find no way to adjust the Shutter Speed on the fly if needed? Do I need to either switch from Apatre Priority mode to Manual or Shutter Priority Mode to be able to increase the Shutter speed?
The same issue arrises when I set My camera to Shutter Priority Mode. I am unable to adjust the Apature Setting on the fly unless I switch Mode to Manual Mode or back to Apature Priority Mode.
I have considered trying PROGRAM Mode, but I am unable to actually highlight and select the "P" in the MODE Menu. I am only allowed to select C1, C2 and C3 which are highlightable adjacent to the unselectable "P".
Any advice or clarification will be grately appreciated. Thankss Again and Happy Hollidays.
Lance A.
12-08-2017 07:50 PM
Sounds like you are running and gunning. I do not use that model, but most high end Canon DSLRs work in a similar way.
You mention aperture and shutter speed, but make not mention of ISO. I typically shoot in Manual mode, using ISO AUTO. If I need to set a specific ISO, I use one of the buttons near the top LCD. If I need to change the shutter speed, then I use Main Wheel on the top of the camera. If I need to change the aperture, then i use the secondary wheel on the back of the camera.
It took some practice to remember what button did what, but after a lot of practice, eventually muscle memory kicked in.
12-08-2017 08:43 PM
Thanks for the response. It appears as though you are useing your camera pretty much as I described, basically manual mode. I either leave the IOS in AUTO Mode, or adjust it manually also.
It's just that I has read and heard that most photographers use their cameras in Aperature Priority Mode. So, I thought that I MUST be missing some quick, simple and fast adjustmemt capabilities for Shutter Speed and or IOS. Maybe it's just not going to be as simple as I thought that it would be?
Lance A.
12-08-2017 09:06 PM
The whole point is that you set the Aperture for the desired depth of field and the camera sets the shutter speed and ISO to get what the camera thinks is a good exposure. The only way to do a quick adjust of shutterspeed would be to fix the ISO and then use the exposure compensation to bump the shutter speed.
Since the Aperture and ISO are fixed, the camera will have to adjust the shutter speed to get the right compensation.
12-09-2017 12:15 PM
Yep, that is how I thought things would word, but with the camera in Apature Priority Mode, I attempted to photograph several large water birds in flight (in the back yard, /central Florida) and there was NO auto shutter speed adjustment. All photos were blurry. So I have put the camera on Manual Mode and then leave the Shutter speed between 1/1000-1/1600 to assure that I will freeze birds in flight if needed. I am still learning all of this so please be patient with me. I am playing with the correct Shutter speeds to capture a moving target still motion while the background is appropriately blurred to show movement.
You folks are more help to beginners like me than you probably realize. Thank you and Happy Hollidays,
Lance A
12-09-2017 01:25 PM
@LanceA wrote:Yep, that is how I thought things would word, but with the camera in Apature Priority Mode, I attempted to photograph several large water birds in flight (in the back yard, /central Florida) and there was NO auto shutter speed adjustment. All photos were blurry.
Lance A
Photographing birds in flight, BIF, is tricky. Not everyone is able to do it well. It takes muscle memory familiarity with your camera, and it begins with using AI Servo Focusing Mode. Canon has created special PDF manuals that address the sophisticated Auto Focus tracking behaviors that are available when using AI Servo mode, which focus tracks moving subjects.
Tracking BIF also requires muscle memory familiarity with your lens. Speaking of which, what lens are you using for BIF? Quality super telephoto lenses have different switches that alter the focusing behavior, and many can adjust the image stabilization behavior.
All of these controls and flexibility can be your best friend, or your worst enemy. Sit down with the manuals, for camera, lens, and focusing guides, and go through basics. Do not expect to absorb it all in one sitting. As I have noted above, it takes “muscle memory familiarity”, which means you need to practice at it.
Birds can be difficult to learn. I practiced with larger, slower moving subjects, like kids playing Little League, or seagulls by the waterfronts. Most gulls tend to glide, without many sudden changes in direction and speed.
12-14-2017 03:40 PM
@LanceA wrote:Thanks for the response. It appears as though you are useing your camera pretty much as I described, basically manual mode. I either leave the IOS in AUTO Mode, or adjust it manually also.
Lance A.
Most photographers using Aperture Priority comes from the days when Auto ISO wasn't as good as it is today.
12-09-2017 12:58 AM
What you should do is to use M mode and set everything manually but in situations you need to be fast, just switch ISO to Auto. You get to set both aperture and shutter speed and let the camera handles the ISO.
In situation that the camera metering is fooled (too bright or too dark background) while on Auto ISO, you need to use exposure compensation to get the desired subject properly exposed. Just remember if background is too dark compensate to dark and background too bright compensate to bright (dark/dark, bright/bright - very easy to rememeber).
12-09-2017 12:19 PM
I have alreadt gravitated to Manual Mode with ISO in Auto (simply by trial and error). I will ABSOLUTELY follow your advice.
Thank You and Happy Hollidays.
Lance A
12-09-2017 07:03 AM
It sounds to me that you have bought a camera with controls that exceed your current photographic knowledge, that is not necessarily meant as a criticism because at least it gives you room to learn.
Although asking questions on here will help you it also means you will get some replies that make things seem even more complicated, you are far better reading an article that covers the complete subject such as :
http://cpn.canon-europe.com/content/education/infobank/camera_settings/shooting_modes.do
