11-10-2017 09:43 AM
I´ve the Auto Rotate (5DIV) feature turned on, both for Camera and Computer.
Why does my portrait images do not auto rotate when I push the play button on my camera for reviewing purposes?
I´ve to rotate by hand each image in order to take advantage of the back screen in portrait mode .-( Not nice when showing images to clients.
Is there a way to let the camera rotate the images; like an iPad?
Thank you.
11-22-2017 07:41 PM
Hello Cunha,
It sounds as though you probably have Auto Rotate correctly enabled in the camera. This feature will make it so that image captured in the portrait position will appear right side up as viewed when the camera itself is held in the landscape position. If you were to rotate the camera and LCD into the portrait position, the images would stay rotated in their original position and not fill the screen. The image will not auto rotate like those taken with an iPhone or iPad.
11-22-2017 07:41 PM
Hello Cunha,
11-23-2017 12:29 PM
Hi Tim, thanks a lot for your reply. If I shoot with the camera in landscape mode it will show images in landscape. The same with portrait orientation. Understood. Thanks again.
