Reply
Occasional Contributor
AEL doesn't lock
Why is it that on say a 5Dm4 or 5DS the AEL feature turns itself OFF the very moment I take a shot and then get into the menu/screen system.  I am a wedding photographer and sometimes I like to lock the exposure (e.g. a sunset) and then adjust the flash output on my Bride using the menu system which is easier to do rather than on the flash head itself in the dark.  In other words AEL is not 100% locking if you want to do anything with the menu after taking the shot.   Unless I am doing something wrong?
Esteemed Contributor
Re: AEL doesn't lock
In the case you cite, why not just expose for the sunset and let the flash decide on the amount of light needed for the bride? I believe any ETTL speedlite has a mode that lets it do that. Then you don't have to mess with the menus after you've locked the exposure. Indeed, I don't think you even have to lock the exposure.
Bob
Boston, Massachusetts USA
Hi Bob, thanks for your reply.  Yes I use the flash in ETTL mode, however it is not always accurate, So when we take the first shot typically we need to FEC (Flash Exposure Compensation) the flash up or down. Within the menu systems now there are controls to very quickly do this, and there are also controls on the flash itself but using the menu system is easier especially in low light. The are various ways of achieving a bridal sunset shot, e.g shoot in manual or AV mode, flash on manual or ETTL. Wedding photographers mosrly use AV mode and ETTL because it is quicker. It can even be a quicker process when using AEL and simply pointing the camwra at the sunset, AEL the exposure, and fire away. However as soon as I access the menu system( to adjust the flash power up or down if I need to) AEL turns itself OFF. It's just annoying and means I need o point at the sunset again to get the exposure and then AEL again.   SO to summarise AEL is not really AEL, it unlocks as soon as you do anything in the menu screen. I'd love to ask Canon why did they design AEL that way and can they fix it :-)
Honored Contributor
The camera is behaving as it should.  Save the settings as preset, with or without auto update enabled.  I go without auto update enabled.  I use C1 and C2 for two shooting scenarios, and use C3 for a scratchpad.
Respected Contributor
AEL is a short term exposure lock.
Fully Manual mode is for long term exposure lock.
Set up your camera for fully Manual operation (manual shutter, manual aperture, and manual ISO), and then practice changing the parameter you want to change (Tv,Av, or ISO) until you can do so without even thinking about it.
Waddizzle, yes there are various ways/methods to use the camera, e.g. the C settings as you have described etc. BUT my point is AEL (Auto Exposure Lock) is supposed to LOCK the exposure which it does perfectly EXCEPT the moment you get into the menu screen it unlocks itself, and that is not optimal in my opinion. LOCK should be LOCK right?. Even if you just want to review the image, zoom in or whatever, it UNLOCKS.
When you're a wediing photographer, and even more so when your style is photojournalistic, AV mode in my experience is always that little bit quicker and safer than manual mode. AE has always been for short term exposure locking, but AEL is supposed to LOCK the exposure for as long as needed. That's why it is called AE L. It's a shame the LOCK feature doesn't stay locked on though when accessing the menu system. If it did I could work a fraction faster.  So anyway unless they change it then yup I'll have to continue setting the exposure manually and adjust the flash output as needed.
I'm not suggesting that you use ETTL at all; I'm suggesting you use External Flash Metering. If you do that, I think you can let the flash adjust its own power while the camera concentrates on the sunset. It's described on page 36 of my 600EX manual (which probably isn't the latest one).
In all probability, the reason you're having to use FEC is because of the ETTL algorithm's proclivity to treat all flash as fill flash. I find that ETTL works pretty well if what I want really is fill flash (or if I'm using bounce flash), but that it's fairly useless otherwise.
Bob
Honored Contributor
Let me ask you this.  You might find the behavior inconvenient, but I think most photographers would not.  If not when you go into the menus, then when should the AEL lock release itself?  The current behavior locks when it should, and releases when you go into the menus.  I see nothing wrong with that behavior.
Like I said, I use a preset as a scratchpad to hold settings when i want to retain them for a short period of time.  Besides, you can always “lock” the exposure by using Manual mode.
In my opinion the AEL should release itself ONLY when I hit the assigned button that turns it on and off. i.e. I decide when. The whole idea of locking something is to lock and unlock it manually, not have it unlock by itself. There are times this is inconvenient, a) As i explained when trying to operate the various flash controls via the menu, b) when reviewing an image(s) zooming in peaking at the histogram etc, and I am sure there are others.  I'd be interested to know if NIKON or SONY AEL is the same as Canon.
I'm going to experiment though with your scratchpad method.
powered by Lithium
