Reply
Occasional Contributor
Accepted Solution
80D ISO Noise concern
[ Edited ]
I just bought a brand new 80D.  I bought it to replace my 7D as I wanted to get improved high ISO noise performane.  My first day of shooting leaves me very dissapointed.  Is this typical of what I am to expect?
Link to higher resolution
http://lonestarnorth.ifp3.com/#/gallery/test-gallery/iso-80d-320/
Here is a screen shot of ISO 640 F8 and the sewcond at 320.
Reputable Contributor
Re: 80D ISO Noise concern
I don't really see any noise of concern, but I use a phone right now. What about you upload a raw sample?
My Swedish blog
M5, 7D, 6D, D30, 300D, 1000D IR, EOS DCS 3c, EOS D2000, 16-35/4L IS, 100/2,8 Macro, 70-200/2,8L IS II, 24-105/4L, 85/1,8, 50/1,4, 24/1,4L II, 300/2,8L IS, Helios 58/2
Darktable, RawTherapee, Photomatix, Luminance HDR, GIMP 2.9.9.
Ok, saw it now. I would say noise is more visible when it is in an area that is out of focus, but please upload a raw sample and we can check.
My Swedish blog
Respected Contributor
Did you  brighten the noisy background or is this as is?
I think it looks normal for the ISO 640 picture but ISO 320 photo is a bit noisy, hence the above question.  The key is that you can filter the noise in post easily without much effect to the picture sharpness.
Diverhank's photos on Flickr
I shoot raw but Adobe won't recognize rbe CR2 file so I convert to DNG.  Neither of these formats will upload.  I did give a link to the large files
[ Edited ]
Jpg files are not enough if you want a better answer. Use a filehost.
My Swedish blog
Honored Contributor
That’s odd.  Which “Adobe”?  You probably just need to update your ACR.
It has to do with Adobe Raw not updating to the newer Raw Files of newer cameras.  I have to convert to dng. I am looking at alternates to CS6 and Bridge
VIP
You have several issues.  One is the ACR for CS6 doesn't convert 80D Raw files.  Second I think you are over processing your dng files.  Remember less is more in post editing.  And lastly, the noise will be worse or at least appear worse in under exposed areas and when you do large crops.  Keep those to a reasonable manageable minimum.
DNG is also a Raw image file. It is Adobe’s proprietary image standard that was created to store image data in a generic, highly-compatible format, unlike Raw files that have specific formats based on the manufacturer and camera type.  DNG was invented by Adobe and it is supported in all Adobe applications.   Some other camera manufacturers such as Leica, Hasselblad and Pentax have adopted this standard and use it in their cameras as their supported Raw file format.
Another option is Canon's own and free DPP4.  In your case I would certainly entertain an opportunity to trry it out.
Lastly keep in mind all cameras have limits not just the 7D and 80D.  You just need to know how far you can go.
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
You appear to be confusing Out Of Focus (OOF) areas with noise.
A dSLR with a long lens will have a very shallow depth of field. The area out of that depth of field will be blurry and could be confused with noise. What you are depicting appears to be normal OOF area and not noise.
powered by Lithium
