Reply
New Contributor
Accepted Solution
7d ii ios
 I was changing a lot of settings on my camera.
I use it in TV mode and after my changes  and going back to TV mode my iOS will not stay at 400 or whatever I set it on.  It changes to 6400 or 3200 or... depending on the lighting. I cannot contact Canon support as it is a holiday.
I was hoping someone could tell me what I have done.
 At first I thought it was because I left my white balance on cloudy day. But I changed that back to auto and it still changes my iOS settings. I know I'm missing something I just can't figure out what.
Esteemed Contributor
Re: 7d ii ios
You have most likely set it to AUTO ISO in a menu.
Super Contributor
Re: 7d ii ios
It sounds as though you may have set it to auto ISO, if this is the case then you will see the letter A on the top LCD.
New Contributor
Re: 7d ii ios
No letter A :smiley frustrated
Re: 7d ii ios
I'm thinking in one of the menu items rather that in the normal ISO setting method.
Super Contributor
Re: 7d ii ios
Press menu, go to 5th group from left (camera with dots under), select safety shift and turn it off (disable). It looks as though you have got it set to ISO at the moment.
Super Contributor
Re: 7d ii ios
Just to be pedantic:
iOS = iPhone Operating System
ISO = International Standards Organisation
Honored Contributor
Re: 7d ii ios
That does not necessarily mean that ISO is not set to AUTO.  If the metering is active, you will see an ISO setting.
If you press the [Q] button, for Quick Menu, you should see the exposure and camera settings.  If ISO is set to AUTO, you will always see it on this screen.
New Contributor
Re: 7d ii ios
[ Edited ]
 I found that and it took several tries to get the right combination.
 You were right, I had it set on ISO.  It is now set to Tv/Av and I think I am happy.
 Thank you.
powered by Lithium
