03-12-2018 10:36 PM
When I used my tripod arm with my 7d to take a downward photo of an old photo on a table the photo took well and filled my screen when it showed in the view finder window. However, when I reviewed it, the photo showed sideways, the opposite way in which I took the photo. When I took out my card to put on the computer all the photos were now verticals instead of horizontals. I can turn them in editing but i just need them to stay horizontal photos. Is there a setting on the camera that will keep them from changing from horizontal photos to vertical photos?
03-13-2018 07:05 AM
Go into your menu setting under the wrench symbol, select auto rotate and turn auto rotate to off.
Rodger
03-13-2018 07:05 AM
Rodger
03-20-2018 11:48 AM
Thank you. This solved my problem.
