04-06-2013 05:52 PM
My 7D pop up flash has just stopped firing. It is a 6 month old 7D, purchased new and up unitl yesterday it fired. What is going on, is it burnt out? The flash itself does not pop up on it's own, it only poped up on its own the first few days, after that I had to pull it up manually but that never stopped it from firing before.
PLEASE HELP!?
04-06-2013 07:39 PM
Have you read your manual? Are you shooting in AUTO most of the time?
IF you put the camera into P, Tv, Av, M & press the button will the flash pop up?
Do you know that you have a menu choice that allows turning the flash OFF even it it's up.
04-06-2013 08:21 PM
04-06-2013 09:47 PM
Warranty repair is my next choice.
04-06-2013 11:36 PM
The flash should pop up even if "flash fire option" has been set to off. When you press the flash button, do you hear the motor sound of the flash popping? If there is a sound, maybe the flash got stuck. If there is no sound, try a new fully charged battery. For some reason, on the 7D, sometimes it gives this problem if you leave a camera off for a while. Otherwise, you can try to do hard reset your camera (take out the main battery and back-up battery also). It normally resolve most of the problem. Good luck.
04-18-2013 11:27 AM
Before you send it in for repair, try one thing... inspect your camera hot shoe carefully you will see a tiny black switch that is designed to be depressed when you install an external flash. This tells the camera you have an external flash and it disable your internal flash. When the external flash is mounted, the thin metal plate above the switch is depressed pushing the switch down. That thin metal plate doesn't go back up sometimes after you remove it. Sometimes a piece of dust get in between the two.
Use a thin piece of paper and run through the area between the switch and the metal plate above i50t then try your internal flash again. This happens to my 50D all the time.
11-02-2014 12:00 AM
