Reply
Esteemed Contributor
Re: 6D Mark ii- Are the owners satisfied? I backed away from it based on the bad internet reviews..
ebiggs1 wrote:
If you want a 6D Mk II with grip it is great.
Well said, and the operative word is "If".
When making such a decision, it's worth noting that one of the most effective ways to make a camera no longer fit into your camera bag is to mount a battery grip on it.
I found that I was much more likely to have to change flash batteries than a camera battery during a shoot. So if you're willing to add that much size and weight, I think a belt-mounted battery pack to power your flash can be a lot more useful than a grip.
Bob
Boston, Massachusetts USA
Honored Contributor
That is true.  I discovered that fact after buying a grip, that I needed a new back pack.  But, only because I could no longer fit the camera in the bag with a lens still attached.  Besides, I needed a bigger bag, anyway, to hold s lens like the 70-200 f/2.8 and the 100-400 “L”.
I think the battery grip gives the camera better balance.  I’d rather not have to change batteries in the field.  i would much rather be able to fire off 1500-2000 shots, and still have plenty of charge left.  Having the beefier battery also gives the camera better control of the focusing motors in the lens.  That’s just a fact of Ohm’s Law.
Occasional Contributor
I'm really confused about the posts in this thread particularly the ones where there are claims that the 80D is better than the 6D II. I've been trying to decide what camera to get and I'm leaning towards the 6D II. The 80D was on my list because it can be had for $699 at some stores online. I currently have a 77D and I'm not happy with it for a number of reasons, mainly in that the AF is too hit or miss. Basically I'm tired of double checking every image and I want it to be in focus when it says its in focus. Honestly its so bad I want to ditch Canon. I just can't fathom a D series camera that doesn't even accurately confirm focus. Hence my need to upgrade. That said I have gotten great images out of the 77D and when it's in focus its spectacular.
I assume that what has happened is that I've bought a camera with similar specs on paper but in reality its tuned to be a little worse to justify the lower price. I just wonder if some of that is happening with the 80D or 6D II. I think with the 6D they chose to lower the dynamic range a touch but I'm wondering what secret handicaps the 80D has been bestowed with?
People often make the same arguments about 77D vs 80D, same sensor, same AF, basically the same performance right??? WRONG.
Anyway, I'm still leaning towards 6D II because its FF and it has great low light performance but the low price of the 80D is compelling.
I think for my lenses I would prefer FF as well.
I really want to skip the 5D for now because I'm waiting for the 5DS II.
Any thoughts or am I on my own?
It's easy to overthink a decision like this. If you're planning to go FF, get the 6D2; otherwise get the 80D.
Has the 5DS sold well enough to justify a Mark II model in the foreseeable future?
Bob
VIP
"I'm still leaning towards 6D II because its FF and it has great low light performance but the low price of the 80D is compelling."
If I were you, today, and I wanted a new camera and the choice was between the 80D and the 6D Mk II, I would buy the 80D. All day long!  Its a no brainer if you think it through.
A camera can not be thought of separately by itself.  You need to consider it as a combo with its lens.  Cameras do not take a single photo without a lens.  OK what lens?
The EOS 80D and the Canon EF-S 17-55mm f/2.8 IS USM Lens.  Why is this good?  It will cost you about $1800 to $1900 bucks.  The 6D2 can not use that lens.  A similar lens for it is the Canon EF 24-70mm f/2.8L II USM Lens.  But now you are looking at nearly twice the price. $3700 bucks.  Twice !
If you can make a statement that the 6D2 is better than the 80D, which I don't believe for one second, but let's say so, is it twice the cost better?  Not on your tootie-toot-toot.
Now, true, you could opt for the Canon EF 24-105mm f/4L IS II USM Lens at a more reasonable price of $1100 but now you just gave up whatever little low light advantage the 6D2 may have had over the 80D.  Still at three grand, however.
Now which camera sounds like the best choice?
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
Thanks for the responses!
After looking at image quality comparisons on dpreview, and after also owning the 77D for a year, I decided to opt for the 6D II. The reason largely being that I believe Canon makes you pay extra for better performance. I know it's borderline paranoia but this is what I believe. It may simply be a matter of quality control in the factory but I believe they give you a better camera at the higher price points.
Logically speaking the 77D should be basically equal to the 80D, but let me tell you something, it is a bit of a dud. The AF is so off half the time. I'll take 5 pictures on a tripod, centerpoint only, refocusing everytime, and the focal plane moves around front and back. It's frustrating as hell. I had a 5D before this and while not the best AF system in the world when it said it was focused it WAS BLEEPING FOCUSED!!!
So it's my experience that somehow, someway, the quality is down with the price even if the spec sheet says otherwise.
I've also read some blog posts that say the 6D II's dynamic range is higher than reported by DXO reports.
Anyway, I really appreciate the help and the discussion but end of day I gotta go with my gut and my gut says 6D II.
Also, I already own 4 top shelf FF lenses, so there's little point in investing in APS-C only lenses.
Honored Contributor
Upon closer inspection, the 77D lacks many features that have standard on recent ##D models. The 77D lacks a lot of nice features.
  • It lacks AFMA.
  • It lacks Custom Shooting Modes.
  • It lacks custom temperature setting for White Balance
  • It lacks exposure compensation in Manual
I sure if I keep looking I might find something else I like, but is not available on a 77D. I suspect the viewfinder display in AI Servo mode might be little crippled, too. I wonder if you can see the tracking display of AF Assist points.
New Contributor
[ Edited ]
@sceneitwrote:
"Anyway, I really appreciate the help and the discussion but end of day I gotta go with my gut and my gut says 6D II."
I think you made a good decision.....
I shoot with both the 80D and the 6D Mark ii and love both cameras. Coming from the Rebel Series I bought the 80D in the spring of 2016 and bought the 6D Mark ii last September 2017. (even after reading and watching all the Youtube negative reviews). I don't regret buying the 6D2 for one second! It's a great camera. One can pixel peep any camera to death if that is ones desire to do so!
I almost always carry both cameras with me on my shooting adventures/outings but mostly only use the 80D for my long lenses for the added reach. My 6D2 is the camera I 99.9% of the time grab for almost any type of shooting. Both cameras have outstanding image quality. Concerning image quality the 6D2 I would only give it a slight edge to as the better camera over the 80D just from my experience using both cameras extensively. Shooting with the 6D2 now for over the last 7 months I do prefer the full frame over crop cameras.....except I always use the 80D with my Canon 70-300mm, Sigma 150-600mm, and some vintage lenses.
If I had any complaints about the 6D2 it would only be the 1/4000 shutter speed limit as I also shoot with a lot of old vintage fast lenses and in bright sunlight I often need to go above 1/4000's of a second (but thats when the 80D comes in to play). Once in a while I have this issue with my Tamron 85mm f/1.8 lens too on the 6D2 which is a bit frustrating. As for all the internet hype and bashing on the 6D2 about its bad dynamic range, well, I haven't really had that problem with this camera much. There has been a time or too when I had to bracket a few landscape shots, but I probably would of had to do that anyways regardless of what camera I was using.
I must say that pairing this 80D with the 6D2 has been one of the best decisions I've ever made.....The 6D2 is probably one of the most under-rated cameras of 2017 and I have no regrets buying it regardless of all the negative internet bashing done on this camera................
[ Edited ]
That gave me a laugh.  Do you know a single company that doesn't charge more for its higher-spec products?  Why else would they make more than one? Smiley Happy
VIP
"...than reported by DXO reports. "
For several reasons I don't like or trust DXO tests.  Just because they claim something don't make it so.  Plus photography gear works a whole lot differently in real world situations then it does in a lab test or pretty chart.
" I decided to opt for the 6D II."
Now you nee to stop reading reviews and learn your new toy. Stop comparing it to others. That is the only way you will get the best from it.  Good luck and enjoy!
powered by Lithium
