Reply
New Contributor
Re: 6D Auto Focus
" focus distance limiter"."  Not sure what that is.  Are you saying I was too close?  i've been closer to other objects with no issues (3-4ft)
Honored Contributor
Re: 6D Auto Focus
It is a switch on the lens.  Your distance from the bird is close enough to the transition distance to warrant using full range mode.
Frequent Contributor
Re: 6D Auto Focus
[ Edited ]
If you are talking about the focus distance selector, I doubt very much that this is the problem. Even if set to 3m to infinity he should have focus lock as he was further than 3 meters away from the subject. I always have my 100-400 II set to the 3m to infinity position.
Greg, did you get a focus confirm before firing?
New Contributor
Re: 6D Auto Focus
Ah, that switch.  I also always leave it set to 1.8m and never had an issue.
Yes, I did get confirmation (beep and lock) of focus.  If you've never used the Focus_point Lightroom plugin its pretty nice (first image).  As you can see from the plugin, the camera registered the focus lock too.
The "only" thing I can think of was the Aperature and depth of feild.  even at that, something should be in focus.
PS.  Great forum and thanks for all the suggestions.
,Greg
Re: 6D Auto Focus
Is this an isolated incident or is this something that happens a lot? Is this lens new to you? If it happens consistently then I would say the lens is not properly focus calibrated. If that were the case then I would think every picture would look just like this one.
I can't see any reason why this would have happened.....all that you did before firing seems right and, in theory, you should have gotten good results.
If it's something that happens often I would call Canon.
powered by Lithium
