09-25-2017 09:02 AM
I found a fix to my problem and I’d like to share it.
Problem: After a couple of apparent failed Magic Lantern firmware loading attempts, my 60D would only turn on if I followed this specific procedure.
Backstory
I wanted to load Magic Lantern onto my 60D. The install failed twice. That is, I saw Install Successful dialogs after each install but when I repowered the 60D, Magic Lantern would never fire up. On my 3rd attempt I noticed the 60D stopped powering on at all. I began to panic because it felt like my awesome camera had become a paper weight.
After struggling with the unit I discovered I could power it on but only by following the exact steps above and in that order. I tried connecting the EOS utility and that did connect but there was no way to reload firmware from that program. As soon as I would open the memory card door to insert a memory card, the unit would shut off and would not power back on after the card was inserted.
I pulled the battery from the camera, and frustrated I went to bed for the night.
The following morning I had an idea: try a different memory card. And that seemed to work.
The alternate memory card had nothing but the latest firmware version 1.1.2 on it and I installed it as quick as I could. The camera seems to be working well now.
I have given up on installing Magic Lantern.
I hope the above helps.
09-25-2017 01:47 PM
Hi TCampbell,
ML wouldn't install until I reverted back from 1.1.2 to 1.1.1. They also provided a version of 1.1.1 and I installed it.
My 60D is back to having 1.1.2 installed on it and is working well. I'm happy this is over.
09-25-2017 09:53 PM - edited 09-25-2017 10:29 PM
If you want support when you have a failure with Magic Lantern, I recommend the Magic Lantern forum instead.
The times I have had a failure has been when I have opened the memory card slot before the camera finished writing data to the card. Then I will need to unmount the battery.
I wish Canon add some of the things ML has, for example raw histogram.
09-25-2017 10:36 PM
Hi Peter,
I didn't start this tread wanting or asking for support. I wanted to pass on to the Canon community an issue I encountered and a solution that worked for me.
Thanks for the tip on waiting for the data to be written before pulling the card. I also like to turn off the unit before I remove the card.
Pulling the battery and reinserting it was a required step for me to get my camera to turn on prior to switching memory cards. It was driving me crazy.
