Reply
Frequent Contributor
Re: 5DSR in LiveView 16x magnification, question.
Agree ,-D
Good lenses, especially if they are manual only, last a lifetime .-) like Zeiss and others. Metal and glass.
Just one word about "banding"; the correct word is maybe "posterization". To avoid it one should edit ias much as we need, inside the RAW engine at the highest bit rate. After that, I work with TIFF 16 bits to add some plug-ins effect and that is when I see the problems.
I must avoid plug-ins or at least less heavy use.
But of course good technique is key and higher D.R. will help too.
Thinking again about the 5DsR vs the 5DIV; the IV has a 10x magnification in LV for critical focusing with manual lenses. Not 16x like the sR but, the screen has higher resolution. Could this be better than having 16x magnification?
Of course the Dual Pixel CMOS AF, will do nothing with manual lenses.
Esteemed Contributor
Cunha wrote:
Agree ,-D
Just one word about "banding"; the correct word is maybe "posterization". ...
Perhaps. But banding and posterization are two different phenomena that should not be confused with each other.
Bob
Boston, Massachusetts USA
Help me clarify, please .-)
I'll try, while not posing as any sort of expert:
banding = visible horizontal strips of contrasting color extending from one edge of the frame to the other.
posterization = overall loss of color differentiation, resulting in patches of solid color where gradations between two or more different colors would be expected.
I suspect that one or more of the others may be able to phrase it more accurately.
Bob
Thanks.
Hardware limitations (sensor/camera signal processing/resolution)?
Use (or abuse) of software (I mean editing)?
[ Edited ]
Cunha wrote:
Thanks.
I think it's fair to say that banding is invariably the fault of the hardware. But overuse of software can make it worse.
Posterization pretty much has to be due to software abuse, but sometimes the lighting conditions leave you little choice. If you can't just walk away from the picture, you do what you have to do.
Bob
Right .-)
powered by Lithium
