02-28-2017 08:35 AM
5DSR users.
I use manual only lenses from Canon and Zeiss with my Canon camera. Manual focus is sometimes an hard task with the Canon MP-E 65mm super macro or the Zeiss Planar 85mm. I was considering a loupe, like a Zacuto Z-finder; for critical focus.
My current camera is the 5D Mark III but I´m considering an upgrade to the 5DSR.
Will this 5DSR unique feature in LiveView; the 16x magnification; avoid the purchase of a loupe?
Thank you very much for all the help.
Regards.
03-01-2017 12:06 PM
Here is a example and opinion from a professional photographer; a person I really trust. The camera in the video is a Nikon but he uses Canon and many other cameras:
https://www.youtube.com/watch?v=Z9OPf-YOMp0
Many other photographers are using a loupe for manual lenses.
It helps the focusing process, cuts glare, etc.
03-01-2017 12:37 PM
@Cunha wrote:Here is a example and opinion from a professional photographer; a person I really trust. The camera in the video is a Nikon but he uses Canon and many other cameras:
Thanks for the link...now that I see it in the proper context...it makes sense if you are mobile and not on a tripod - you can get a fairly stable view with the loupe - even though I don't find it necessary personally to use a focusing loupe but I can see why someone wants to use it.
To get back to your question...the 16X magnification will be too shaky if you're not on a tripod so my answer would be you can't replace the loupe with the 16X...they are two separate things. Maybe a cheap 1 or 2X loupe in addition to the liveview magnification can be the answer but I maintain that the 10X is more than enough so if it's just for the focusing, upgrading to a 5DSR is not necessary. I did learn something new about focusing loupe. Thank you for that. Hank
03-01-2017 02:58 PM
That´s the beauty of a forum. I´m glad you learn something new.
The upgrade isn´t just for the 16x magnification .-) It would be a silly move.
At the moment the 5DIV is a better camera concerning DR, noise, etc.
Even if I need as many megapixels as I can get, maybe I can live with less, but also with less noise and banding problems (but that´s another discussion).
And yes; at 16x it will shake. With my MP-E 65mm at 5:1 it will shake like an earthquake.
The sweet spot is maybe 10x and a less expensive loupe, when needed.
Thanks.
03-01-2017 03:09 PM
@Cunha wrote:That´s the beauty of a forum. I´m glad you learn something new.
Thanks.
Shake? Use a stronger tripod and head. Off center loads will push any rig to its limits. I suppose there is little you can do 5:1.
03-01-2017 03:11 PM
03-06-2017 09:55 PM
03-07-2017 06:46 AM
Thank you very much for your report.
You find the 16x helpful in LV using manual lenses; correct?
Would you please explain a bit better why you wrote "make sure you understand the differences between the 5D IV and 5DsR, I love mine but occasionally still use a 7D"?
Apart from the specs (megapixels, etc) the main difference I find between the 5DSR and the 5DIV is that the IV has a new generation sensor with a different way of processing the signal (at last) with much better results concerning noise and dynamic range. That´s also very important to me because I´m very tired of noise and banding .-(
Why did you mention the 7D? Smaller files? Number of Pixels for the size sensor?
Thanks.
03-07-2017 07:18 AM
As far as vibrations go when you are 10x or 16x, I would point out that vibrations are the bane of cinematographers, too. They are always turning a zoom ring, or a focus ring, while filming or recording. They use rigs that tend to be extremely stable.
I have switched to using video tripods almost exclusively because of their strength and stability. But, cinematographers also mount their cameras very differently on their rigs compared to how a typical DSLR user would. Your typical DSLR camera is attached to a tripod head at one point. Your typical video camera is frequently mounted on a rail system which can frequently attach to a video head at two points. One mounting point is under the camera body, and another is under the lens.
Two mounting points provides a MUCH more stable platform compared to one mounting point. Also, fluid video heads tend to have a large platform, or mounting plate, to accommodate more than one point of attachment. Food for thought.
03-07-2017 12:41 PM
Very good points .-) in a good hour, for me, as I´m about to upgrade my tripod/head to improve my results. Thanks.
03-07-2017 11:51 PM
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
