05-06-2013 02:59 AM
Hi all
I would like to know your opinion about the following issue:
In the viewfinder you see the set ISO value. This value can be altered without having to take the camera off the eye when your individual settings are accordingly: Press SET button and turn the main dial.
This is a very valuable setting as it makes it easy to have control over the ISO settings as well as over the Aperture and Time.
Now unfortunately it is not possible to turn the ISO value back to "Automatic". For this you have to take the Camera off the eye and go into the menu to change that value. This should be changed.
What is your opinion about this?
Regards, Alex
