09-29-2016 12:42 PM
Why does the 5d Mark IV create larger file size than its predecessor at same fps/res? any solutions beyond switching from ALL-I to IPB?
09-29-2016 08:56 PM
09-29-2016 04:21 PM
@Jwattsy wrote:Why does the 5d Mark IV create larger file size than its predecessor at same fps/res? any solutions beyond switching from ALL-I to IPB?
Are you shooting 4K video instead of 1080P?
09-29-2016 04:27 PM - edited 09-29-2016 04:39 PM
No Sir, it's set .mov "FHD 23.98" which the manual says is "full HD" or 1080p. 4K files sizes are even bigger (7min on a 32gb card - which was to be expected).
09-29-2016 08:53 PM
How big of a difference in file size are you seeing? Are you shooting with mono sound on one camera and stereo on the other, or using an external mic? Are you shooting the same subject matter with both? Still images will make bigger files when shooting a scene with more detail or color, or color gradations. I would think video would act similarly.
09-29-2016 08:56 PM
