04-29-2013 06:01 PM
I cannot turn on the camera. The access lamp will flash once (long) followed by a short flash.
Two fully charged batteries an three CF cards were tried.
This seemed to happen after I deleted all photos on the CF cards. Could this have caused the problem?
05-07-2013 09:44 AM
04-29-2013 06:05 PM
I don't think CF card can cause the camera to do that. Maybe it's a battery problem. This camera is kind of old already. So the battery may not be working anymore. Is there a way that you can get a new battery?
04-29-2013 06:13 PM
Thanks for the reply but,I have new fully charged batteries and neither worked. One is OEM and one is after-market
04-29-2013 06:33 PM
04-29-2013 06:37 PM
In a reply about a similar problem a while ago someone suggested VERIFYING that the switch for the CF card door is being activated by the door. Never having owned a Rebel I can't tell you exactly how it's activated but it may be by a small pin on the door which may be breakable. Take a carefull look at the door & area to see if you can see what might be a switch & if you find it & see how it should have been activated try a toothpick or like item to depress it & see if that fixes it.
04-29-2013 07:40 PM
Both batteries indicate fully charged on the battery charge and check good with a voltmeter.
The battery and cover switch also seem good since inserting a battery and closing the battery cover activate the access light.
Update - the access light will illuminate for one long flash followed by two Short flashes.
05-07-2013 09:44 AM
