03-13-2015 03:19 PM
03-15-2015 09:50 AM
Hi jim1!
If you need the flash to fire all of the time, regardless of what the camera may determine is necessary, switch the MODE DIAL to the P mode, then press the FLASH button to raise the flash. If the flash is raised, it should fire each time you press the shutter button.
05-20-2019 10:56 AM
Hello Forum;
That flash button is hard to find on my Canon EOS Rebel T3. I thought it was on the back but it's on the top.
Question: Is there any way I can force the flash on in the CA setting?
Thank you in advance.
Pete Norris
05-20-2019 11:54 AM
Nope. The Camera is totally in control. That is why you need to switch to "P".
05-20-2019 12:41 PM - edited 05-20-2019 12:42 PM
Thanks.
