07-23-2016 11:12 PM
Folks,
I need some help. I just got a T6S and my Sigma 17-70 2.4 works fine except when I want liveview of try to use video mode. Neither will display anything on the LCD. The lens works fine on my T5i body, including liveview and video. My other lenses seems to work fine on both my T6s and T5i for Liveview...
Any ideas or help?
Stilgar99
07-25-2016 09:56 AM
Google is your friend.
http://www.sigma-photo.co.jp/english/new/new_topic.php?id=514
07-24-2016 07:59 AM
When you say display nothing do you mean black display?
I ran a test on my T4i. With no lens attached LiveView works. If I select video I get a warning that no lens is attached, but if I select record the display works.
07-24-2016 11:10 AM
Yes...I mean a black LCD display....
07-24-2016 11:26 AM - edited 07-24-2016 11:29 AM
The Sigma 17-70mm F2.8-4 DC Macro OS HSM is a very good lens. I highly recommend it. It is in the general same class as the very nice Canon EF-S 17-55mm f/2.8 IS USM Lens. Slightly more range but really pretty comparable.
It should work! The only thing I can come up with is, possibly, Sigma has not tweaked the firmware for operation with the T6s. Since the camera and other lenses work as they should. That would explain why just the Siggy doesn't work well on the T6s.
The Sigma 17-70mm F2.8-4 DC Macro OS HSM is compatible with Sigma's USB dock. It allows you to connect the lens to your computer to update the firmware. Plus some other adjustments. The dock is a feature that Sigma has on some lenses. It guarantees the lens will work properly with future Canon cameras. Purchase the Sigma USB dock.
The Sigma 17-70mm F2.8-4 DC Macro OS HSM is a vast improvement over the standard 'kit' lens. When it works, that is!
07-24-2016 11:43 AM
07-24-2016 11:53 AM
@stilgar99 wrote:
Thanks for the response. I guess Im just trying to determine if I have a issue with my new t6s and need to return it.
I agree that based on the data and inputs from others, it sounds like a lens issue. However it would sure be nice to hear if any other T6s owners have seen this with the Sigma 17-70...
Stilgar
Go online and see if any reviews mention using a T6s. Check some of the largest online Canon retailers, who will likely have the most reviews. I say buy the Sigma Dock, because it can also perform firmware updates on lenses. The Sigma Dock is a good tool to have on hand, anyway.
07-24-2016 12:03 PM
"Go online and see if any reviews mention using a T6s."
I generally don't like that suggestion and I don't really recommend it. You never know if the other owners know what they are doing or not. But I suppose if you did see a preponderance or trend it might be OK.
The Sigma USB dock is the way to go. If the lens still doesn't work after a firmware upgrade, there could be something wrong with the T6s. I really doubt that but, hey, anything is possible.
Get the dock. If the lens still doesn't work I would call Sigma first before suspecting the T6s.
07-24-2016 12:31 PM - edited 07-25-2016 10:20 AM
The Sigma web site has a "DC Lens Compatibility Chart" for their current lenses. It can be found under the RESOURCES link on the lens data page.
http://www.sigmaphoto.com/lenses/lens-resources/dc-lens-compatability-chart
I see the T5i listed for use with the lens, but not the T6s, T6i, 80D, T6, or even the 7D2 or T5..
07-25-2016 09:48 AM
If other lenses work and this *THIRD PARTY LENS* does not, it is probably a lens issue. See if sigma has a firmware update for the lens.
07-25-2016 09:56 AM
