03-18-2015 07:50 AM
First post here. I've just started workig with my new t5i, which I'm using to work on my ongoing video tutorial series. In the manual I see how it is possible to set the audio input level maually for an external mic but I can't figure out how to navigate to the menu that allows me to do this. I have pored over the user manual a number of times and can't find this information. Can anyone help?
03-18-2015 03:52 PM
Same camera in different shooting modes. The menus I described would be for shooting video in "P, Tv, Av, or M". Anything else will give you a smaller menu selection like you have already seen.
03-17-2016 07:51 PM
ok so to set up an external mic on the t5i is that you put the setting on m as shown below and then you foolow the other steps mentioned above
02-26-2017 10:59 PM
When I plug my microphone into my camera and try to adjust auto levels only the auto levels on the top in the left ear moves not that R for right on the bottom and when I listen it only comes out of the left ear what am I doing wrong?
02-27-2017 12:57 AM
@sportcoat17 wrote:When I plug my microphone into my camera and try to adjust auto levels only the auto levels on the top in the left ear moves not that R for right on the bottom and when I listen it only comes out of the left ear what am I doing wrong?
That question is close enough to gibberish that I have no confidence that I understand it. So I'm just guessing, but it sounds as though you may be plugging stereo earphones into a mono jack.
