08-16-2014 06:57 PM
I just bought a brand new sandisk 'extreme pro' 32g card, and set the camera on a windowsill trying to record a jar. It still stopped recording after a few seconds. It has done this with the last three cards I've tried in it. This is pretty much a brand new camera.
08-16-2014 07:16 PM
08-16-2014 08:21 PM
seems like a pretty random (but apparently widespread) phenomenon. The obvious fix would be a firmware update that allows one to choose whether or not the camera aborts or reduces quality momentrarily if the card can't keep up. The camera is completely unreliable for professional use, even as a backup, until this issue is resolved. I usually keep this one on a tripod as a second angle and use a MarkIII for the main shoot, but a lot of good that's going to do if it aborts recording the moment my back is turned! The card I just tried out in it is theoretically the best available, so that can't be it. And it isn't a motion issue, cause like I said, I was recording a closeup of a jar....
08-16-2014 09:17 PM
This is extremely enlightening. Yeah mine does the same thing. I'll record me playing piano or something and it'll cut out within ten seconds. Yet soemetimes it works, this makes it extremely frustrating.
08-16-2014 09:56 PM
perusing the interwebs a bit more, i decided to give magic lantern a try. Seems to be working. (There goes my warranty). Also changed the framerate from 29.97 to 24, but, really Canon...if you're going to sell me a camera that claims to record 1080 29.97 on an sd card you should either sell it with a BIG disclaimer or provide cards that you know will work.
10-25-2014 11:45 PM
10-28-2014 07:29 AM
MajBurke,
It is normal for the camera to stop recording at 4GB. Due to file system limitations, each clip that is recorded cannot exceed 4GB.
10-28-2014 08:32 AM
@inactive010823 wrote:MajBurke,
It's not obvious why those file system limitations should prevent the camera from immediately starting a new file and continuing to record. If, as MajBurke asserted, GoPro has made it work that way, one would think that Canon could as well.
10-28-2014 04:00 PM
Although I understand that write speeds and what not can cause these kinds of limitations it would be nice to see maybe a firmware update that resolves this. Maybe this is an issue that is not seen in the higher spec cameras. I just feel that this limits people on things like timelapse footage and what not.
10-28-2014 04:18 PM
@MajBurke wrote:Although I understand that write speeds and what not can cause these kinds of limitations it would be nice to see maybe a firmware update that resolves this. Maybe this is an issue that is not seen in the higher spec cameras. I just feel that this limits people on things like timelapse footage and what not.
The solution (other than just starting a new file) may not be simple. 4GB is a magic number in the Windows world. I believe it's the maximum file size in the FAT32 file system. To go larger, you'd probably have to format the card with the NTFS file system, which the camera might have to be told (via a non-trivial firmware upgrade) how to support. I don't have a card here at work, so I can't just pop one into a card reader and see what file system it uses. But you could do the exercise at home with any Windows computer. If it's FAT32, that probably explains the limitation.
Even if you could get the camera comfortable with NTFS, you might have a problem with the computer itself. Some tablets, Notably the Surface Pro 2 and 3, have rather limited support for NTFS on USB devices.
