05-29-2014 02:11 PM
Hi Everyone,
First time posting because I cannot find an answer to my really random question. I work with a system that uses the T4i, we are slowly upgrading all the cameras to a T5i. The one thing that has always worked before with the T4i is that while connected to the computer via usb, I was able to push the pop up flash button to pop up the flash, whiel still tethered. Now I have the T5i in the exact same configuration and while connected to the computer, I cannot use the button to pop up the flash unless I unplugg the usb connection. Is this some silly new feature that I am not seeing anywhere in the menu? I do not use the EOS Utility with the system I am using, because I know in the Utility it has the button to pop up your flash, which I don't want, I want to be able to hit the lighting bolt button and pop it up manually. Any answers would be awesome, I am perplexed by this weird change in the camera between the T4i and the T5i. Thanks in advance!
05-29-2014 02:50 PM
That's odd, given that they're almost identical cameras. There were hardly any differences in the T5i "upgrade": some changes to Live View, a coating on the plastic body, and a knob that can turn 360 degrees.
I suppose it's possible that they inadvertantly changed this function when making the modifications to Live View and the display. But the changes really aren't that significant, nor related.
Sorry, I can't really offer any advice. Though I'm curious why you're spending the money to upgrade from T4i to T5i?
05-29-2014 06:08 PM
The T5i and the T4i are nearly identical cameras and not worth the upgrade unless the T4i is failing somehow.
But I suspect the two do not share the same firmware and that is likely where the issues is.
